Question about Nokia 1600 Cellular Phone
Predictive text function on Nokia 1600
For some reason the predictive text function on my phone isn't working any more. It no longer recognises very common words [like "see", "were" and "the"] and tries to replace them with random letters like "qfd". Any advice greatly appreciated, it's doing my head in. Have done the usual technophobe solutions to it, including switching it on and off, taking the battery out and hitting it.
  • 2 more comments
  • Dantd Aug 09, 2007
    That fixed it! I guess I had changed something while it was in my pocket!!! Many thanks, Dan
  • Peia Dec 16, 2007
    Predictive text is off & I cannot find an option to turn it back on. I have tried everything. When I go to the predictive text & the instructions, it states to use the # key, but that doesn't work. Any help is appreciated. Thank you.
  • Anonymous Aug 08, 2008
    1600 nokia mobile network range problem
  • Anonymous Mar 31, 2014
    How do I? - Virgin Mobileredictive text ,where di i find it to switch it on
  • 61 Answers
Hi
in message ->option->dictionary ->english
if it not work then restore the factory setting try # key.
good luck
Posted on Jan 26, 2009
I figured it out. Default to settings didn't help. I had to go to change the language & put it back to English, which restored predictive text.
Posted on Dec 26, 2007
Next
Posted on Dec 25, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
Try to upgrade the software by taking to a techician or to a nokia shop.but first try to restore factory settings,there is un option to settings menu.the default code is 12345
Posted on Aug 09, 2007
SOURCE:
Turn off predictive text nokia
Most Nokia handsets have a button on the keyboard to do this.
Try looking for a button that shows "T9" on that.
Long press it, and the predictive text mode will be toggled.
Jan 26, 2014 | Nokia BL-4S Li-Ion Standard Battery for...
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
I cant seem to remove the predictive text from mt text messages.
While writing a message, go to
Option > Predictive Text > Set the Predictive Text to Off.
Or simply
Go to Menu > Tools > Settings > Language > Predictive Text (set it to off)
May 25, 2011 | Nokia N79 Cellular Phone
How do I deactivate the guided text on my E63?
To switch predictive text input off, press the function key + spacebar and select Predictive text > Off.
or
try this : when texting, just hold down the left navi key (under the screen) for a couple of seconds
Hope this help and if helpful RATE please
Feb 02, 2011 | Nokia E63 Cell Phone
How do I change the language setting to english on
hello
you can try these steps to change your phone's language
Language settings
Select Menu > Ctrl. panel > Settings and General >
Personalisation > Language.
• Phone language — Set the device language.
• Writing language — Select the language used for writing notes and messages.
• Predictive text — Activate predictive text input.
• Input options — Define the settings for predictive
text input.
May 02, 2010 | Nokia E72 Smartphone
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
I cant switch predictive text on
For you to switch to predictive text or T9, just go to your "Text Message" window, when on that application window please select on your "options" button on your cell phone.
You'll have a pop up with scroll options that would either say 'predictive text', just ok the T9 or "Predictive Text" option and you would be able to have predictive text switched on.
Kind Regard
Jul 01, 2009 | Nokia 5500 Sport Cellular Phone
I want to turn off Predictive (spell) text - How?
Hello.
Welcome To Fixya Community.
I am glad To help You Sir.
"To activate/deactivate predictive text input, press # twice quickly.
This activates predictive text input for all editors in the
device."*
*Source:
Nokia E51 User Guide.
Thank You For Using Fixya.
Please Give a good Feedback^^
May 31, 2009 | Nokia E51 Cellular Phone
Predictive Text
Open Tools
Open Settings
Open General
Open Personalization
Open Language
Set Predictive Text On
Mar 19, 2009 | Nokia N95 Cellular Phone
Nokia 6230 Predictive Texting
press the hash key 3 times
Jan 14, 2008 | Nokia 6230
Nokia 1600 Cellular Phone Logo
653 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
