Question about Whirlpool Washing Machines
Whirlpool AW/M 5100 washing machine
Drum is not moving. Have checked filter. Any ideas?
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
yalmer
  • 552 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
mikedurland
  • 481 Answers
SOURCE: Whirlpool washing machine does not work after move
you can check the harness under the control panel and make sure it is not loose from the move.ee653d9.jpg
this is just the first step, so if it is not the problem let me know and I will help you figure it out. Mike
Posted on Aug 07, 2008
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
Whirlpool awm 5100
Check voltage to motor at the time of the start cycle if water has filled, absence of voltage shows that the program controller is faulty, If there is power, then the motor is faulty, if the motor is humming or getting heated then there is friction on the drive, remove and clean the drive shaft.
May 02, 2013 | Washing Machines
Where are the filters on your washing machines I have an old 5100 6 cycle which has been fantastic and due for an upgrade in the interim hoping to discover where the filter is located
Hi just read your posting.Is this machine the 5100 Whirlpool front loader.If it is the the only filter on this machine is the drain pump filter.It is located at the bottom of the machine either behind the kick plate or behind a small door.When you locate the pump filter unscrew it anti clockwise and then clean it and replace. Put some towels down for the water that will come out from the machine.Please reply on how you got on.Looking forward to your reply.
May 22, 2011 | Whirlpool Washing Machines
My Whirlpool washing machine has failed to rinse and spin due to the 'clean pump' light being on. Any advice on how to clean the pump? Thank you.
Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Apr 03, 2011 | Whirlpool Washing Machines
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
My whirlpool awo/d5716 keeps ripping clothes. it looks like they are going down between the drum and door seal. its ripping mostly sleeves and i keeps losing socks which end up in the filter. if i put one...
It may be that the drum bearing has failed, allowing the clothes to get where they shouldn't be. Stop using it. Get a technician in, because it could fail and do irreparable damage
Jan 06, 2018 | Whirlpool Washing Machines
Where is the lint filter on a Whirlpool 5100 washer please?
this unit does have a cleanable filter. i do not know its location. if you do not have a manual, a repair manual can be purchased at repairclinic.com.
Jul 26, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
