Whirlpool awm 5100
Drum not moving. Please advise.
  • Washing Mach... Master
  • 17,130 Answers
Check voltage to motor at the time of the start cycle if water has filled, absence of voltage shows that the program controller is faulty, If there is power, then the motor is faulty, if the motor is humming or getting heated then there is friction on the drive, remove and clean the drive shaft.
Posted on May 02, 2013
SOURCE: washing machine problem
bought a new appliance , seems to have resolved issue
Posted on Mar 12, 2008
  • 141 Answers
SOURCE: AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
Posted on May 06, 2010
SOURCE: why does my Whirlpool AWM
http://www.eserviceinfo.com/downloadsm/14676/whirlpool_AWM5100.html
Above is your service and repair manual. I would think your main controller board has faulted. Most likely it has been spiked or a power surge has affected it. This Board will need to be replaced. All parts are in the service manual, parts numbers too. Now please use the service and repair manual, and perform the troubleshooting steps to isolate this issue and to be sure of our main board diagnosis.
However if you do not wish to DIY, then please contact your local whirlpool service agent and ask for a service call, then ask them for a "Quote" for the repair, before allowing repair work to commence, this way you can make an informed decision as to what to do.
Posted on Sep 14, 2010
SOURCE: whirlpool awm 312 goes through cycle but drum does
hi
a user manual for awm 312?
i didn't find on net.
thanks
Posted on Sep 23, 2010
dcramer531
  • 1654 Answers
SOURCE: Not running through the cycle
Wher is it stopping, if it is stopping on the rinse cyle, it could be a bad pressure switch or plugged tube to the pressure switch, if it is stopping in the spin cyle it could be the door switch not functioning or a plugged pump filter or pump or clogged discharge hoe. The pump filter is ususally an issue, it is under the tub, usually right in front with some sort of cap on it.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. are you getting any codes, these tell us a lot.
If this was helpful a vote of approval for the free help would be appreciated.
Posted on Mar 23, 2011
Whirlpool AWM 123
See if anyone else on Google is having the same problem........
Nov 27, 2013 | Whirlpool Washing Machines
Inlet valve non operational on whirlpool awm 258 nordic
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Jul 27, 2012 | Whirlpool Washing Machines
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool awm 312 goes through cycle but drum does not turn belt is ok
hi
thanks
Mar 14, 2010 | Whirlpool Washing Machines
Drum outlet hose assembly
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Aug 01, 2008 | Whirlpool AWM8103/1 Front Load Washer
Washing machine problem
Mar 11, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
