Magnavox 47mf439b/f7 are these two parts interchangeable or no way?
  • Doce Verde May 02, 2013
    oops! the parts are both phillips magnavox power supply boards. one number is 47mf437b/47 the other one is 47mf439b/f7
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
About which part you are discussing about?
Posted on May 02, 2013
Still having trouble finding a power supply board for tv emerson lf391em4a or Magnavox 39me313v/f7. Any chance anyone could help me find one?
Sorry we have no parts locator service here at this website. All that can be done is use a search engine like Google and keep looking.
May 01, 2017 | Magnavox Televison & Video
Can I fix my LCD Television with broken display screen with a slightly different model?
I have not been able to ascertain the individual panel part # for these units, so my suggestion is as follows:
remove the back from both units & verify the part# of the panel for each. If they have identical part# you can swap, if they are different, try to google each # to see if they may be interchangeable.
Mar 04, 2015 | Televison & Video
How to hook up sound bar to magnavox television
hi
lprokopy
You can connect from headphones out , one like these:
3.5mm to RCA Audio Cable Adapter
to your soundbar
or
you may need a digital to analog converter
http://www.amazon.com/Digital-Audio-To-Analog-Converter/dp/B0013LWK3A
out from SPDIF ( the back of your TV) and the soundbar
Only if the sound bar does not have a digital input.
Sep 29, 2012 | Magnavox 47MF439B 47 LCD TV
How to hook up external speakers
There is no direct port to hook up external speakers. you have to use an amplifer to get connected in between TV and amp, using an AV cable.
Magnavox 32md359b/f7
Main Board bad. The part number is A91F3-MPW S. Change this board fix the problem.
May 10, 2012 | Magnavox 32MD359B 32 in. TV
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Looking for manuel to print out on Magnavox MBP5120F/F7
You can download and print the instruction manual for Magnavox MBP5120F/F7 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jan 28, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do you hook a pc to magnavox 47mf439b/f7
make sure your tv has a vga connector then run a vga cable from your pc to the tv and change the input on your tv to vga. it's that simple.
Jan 06, 2011 | Computers & Internet
Cant find correct magnovox 47mf439b code to use with direct tv remote
I have the Magnavox codes as listed for my Comcast remote and possibly one of these will work for you. ( 0054, 0030, 0179, 0186 )
I have the same TV as you and 0054 worked for my Comcast remote.
Good Luck!
Mar 22, 2009 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
