Question about Water Heaters
I have no power to my switch and would like a diagram to follow the wire, it must be broke some where.
  • Water Heaters Master
  • 5,089 Answers
Copy following wiring diagrams for switch wiring:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/images/Basic-household-circuit.jpg
At a comment and say what you are wiring, and what you have done so far.
Posted on May 02, 2013
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Where can i get wireing diagram no tail lights 1999 Jeep Chrekee classic?
I would go to the Mfg. web site and try to download the wiring diagram. You will probably have to look them over good and make sure it is the correct wiring diagram because on most vehicles made today some have 5 or 6 wiring harnesses they use and you have to find the one that is installed on your vehicle.Vehicle wiring is a headache to say the least. I have run into the same problem and it was a different solution on each of them. I had a 2000 Ford Explorer that had a blue wire with a black stripe and only one end on it! I put a signal tracer on it and it went out when it went through the fire wall. I have used that signal tracer to trace a wire 500' on electrical jobs but the signal stopped at the fire wall. I can tell you this sometimes I would find that the power to the brake lights split off in a switch or the tail lights were powered from a completely different place than where the brake lights were so look elsewhere away from the brake lights for the power to the tail lights.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Hi how to connect one 20amps contactor and a delay timer
Which delay timer do you have? 9 pin, 11 pin, etc?
What voltage are you using?
What is amp rating on timer?
Copy following links for general and specific wiring diagrams:
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
http://waterheatertimer.org/images/ON-delay-timer-diagram-900.jpg
Add a comment.
Gene
hh
Aug 20, 2013 | Intermatic WH40 - Water Heater Time Switch...
How to wire rheem tankless water heater
Open following link to see general tankless wiring instructions, with amp rating and breaker size for various tankless units including Rheem
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Nov 24, 2011 | Rheem Tankless Hot Water Heater...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
Changing out the hot water heater timerswitch
Nema 1 means indoor-only enclosure or box.
For example Nema 3R is raintight for indoor-outdoor box, which is typical for outdoor swimming pool timers.
If you have water heater timer, open following page for common timers with images, manuals and wiring for each.
http://waterheatertimer.org/Boxtype.html
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Water Heaters Logo
80 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
