Question about Printronix P7220 Matrix Printer
How to fix error Weld Not Detect?
Please help me
Why does the wire weld when I touch the metal?
BE CAREFUL. That sucker is hot and you have current going through it! If you get a voltmeter you will detect the juice.
Aug 31, 2015 | Welding Tools
Weld detect error
Ribbon weld needs to be replaced.
Jul 01, 2014 | Printronix P7010 Printer
Hitachi 2006 42HDS69 will not detect signal from dvd or xbox, how do I fix this?
Check the error codes on the digital board, which is visible through the grill in the back where the AC power entry is located. A trouble shooting guide, including the error codes, can be found in the service manual here: http://elektrotanya.com/hitachi_42hdx99_42hdt79_42hds69_chassis_dw2-u.pdf/download.html
In the case of my TV, I had to replace the main digital board. I was able to find one online for about $80 and replace it myself. Once you get the rear cover off the TV the digital board is easily accessible and took maybe 20 minutes to replace. Good luck!
Jun 27, 2014 | Hitachi 42HDS69 42 in. Plasma Television
Weld not detect
ykoymgiccohoideraqepirij0rebaq8hginreqebdyeyideraqepiru8docagicai54jwymwicaglcqwrizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8xp8pkfngr0qq4oeaaaaasuvork5cyii=
Like the problem is not by the user fix it. Check the ribbon, check visually all about it is good.
Jun 25, 2014 | Printronix P7220 Matrix Printer
Weld not detect
Hi
The cartridge weld was not detected.
1.Clear the fault message.
2.If message persists, replace the cartridge.
3.If necessary, replace the weld sensor.
Feb 15, 2014 | Printronix P7220 Matrix Printer
Error ( E000100-0000 ) canon 2318
IN MOST CASES ERROR E007 IS DISPLAYED WHEN THE OPTOMETRIC SENSOR ON THE FIXING UNIT CANNOT SENSE THE THE ROTATION OF THE FIXING FILM WHICH AT MOST TIMES IS CAUSED BY TORN FIXING FILM SIMPLY CHECK AND REPLACE BUT CONTACT YOUR SERVICE TECHNICIAN TO AVOID DAMAGING THE ENTIRE UNIT
Jan 19, 2014 | Canon imageRUNNER 5570 Copier
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
WELD NOT FOUND ERROR
Sounds like a failing weld sensor. Clean it first its on the left side, you can see it when the ribbon is out. If that doesn't help replace it.
May 08, 2013 | Printronix LineJet® P7010 Matrix Printer
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Printronix P7220 Matrix Printer Logo
245 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
