Question about Sharp AR-M455N Copier
METER READING FOR SHARP AR-M455N
HOW TO GET METER READING FOR SHARP AS-M455N
Bubbabear64
  • 2794 Answers
SOURCE: setting the new meter reading
I found it.
To get into service mode press the clear key. Press interrupt.  Press 0.  Press interrupt.
All counter reset codes start with the number 24.  So put that in first and press the start button.
Then type in a 1 press start.
Then type in a 2 press start.
Do this for numbers 3-11 and 13.
That will reset all of the counters on the copier.
Turn off the power once you're done.
Posted on Sep 18, 2008
  • 4 Answers
SOURCE: How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
Posted on Dec 05, 2008
  • 990 Answers
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
tehnik_bdg
  • 91 Answers
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Posted on Apr 16, 2009
  • 54 Answers
SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Posted on Apr 17, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Were is Sharp AR-M455N back print control board (shiny metal + slides out like a draw) remove and refit memory cards
On the back of the main print engine (Main engine looks like a block under the scanner) toward the top. Your scanner unit will be connected to it. I think there is like 3 or 4 screws to take out and then you can slide it out.
Oct 19, 2011 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Sep 05, 2010 | Sharp AR-M455N Copier
Need to download latest printer drivers for Sharp copier AR-M455N
Copy this link to download the driver needed
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 15, 2010 | Sharp AR-M455N Copier
Sharp ar-m455n- f1-15
Finisher liftup motor trouble
Apr 09, 2010 | Sharp AR-M455N Copier
I need a printer driver for Sharp ARM455N
Hi david...
Sharp AR-M455N printer drivers can be found at driverupdate us (xp/vista/7/8/mac).
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Dec 04, 2009 | Sharp AR-M455N Copier
Apr 15, 2009 | Sharp AR-235 Copier
Sharp AR-M455N Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
