Question about Dryers
Shine top ceiling fan switch
Need to know were i can buy a shine top three speed 4 wire pull switch in the us
miguel1017
SOURCE: trying to replace 3 speed
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Posted on Apr 17, 2009
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
brnspncr
  • 67 Answers
SOURCE: wiring diagram for Kenroy 3 speed dual/multi level pull chain
Try http://resource.arcadianlighting.com/Vendors/Kenroy/Docs/34232BS-INS-B.pdf
Posted on Jul 05, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
nascarnbronc
  • 6 Answers
SOURCE: switch on 3 speed 4 wire ceiling fan fell
I have the color codes for that switch but I can send you a photo
nascarnbroncosfans@msn.com
Posted on Nov 20, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
The fan operates correctly, but I cannot get the lights to work. There are 4 candelabra bulbs. The bulb receptacles have 110 VAC on them. Once bulbs are installed, the voltage to bulbs drop out.
There are two ways that ceiling fans are wired.
1. you turn on the wall switch and then you have one pull for the light (on and off), one pull for direction (clockwise, anti-clockwise) and one pull for three speeds and off.
2. you turn the wall switch on and the light comes on. There are two pull switches one pull for direction and one pull for three speeds and off.
Check your wiring from the installation instructions, the wiring in the ceiling.
Sep 29, 2015 | Dryers
3 speed ceiling fan switch installation
Fan is wired wrong, but you need to test using multi-meter.
Buy cheap multimet from hardware, install battery, set to read ohms or the upside down horseshoe symbol
Copy following link for testing wires:
http://waterheatertimer.org/How-to-wire-3-speed-fan-switch.html
Oct 07, 2012 | Hunter (25417) Ceiling Fan
Replacing a pull switch on an Encon fan. 4 wires. Didn't label wires before I pulled them out. Number on old switch is 1282M and 17292101 with A B C D labels. Can you tell me which wires go where? ...
I have just figured out the wiring to my Encon 5TD42WHC ceiling fan. (This is not to say your fan won't be different.) You can't use just any switch; the switches vary in operation. See the images attached. Good luck, and be careful working with AC voltages.
Dec 23, 2010 | Encon Industries (78018) Ceiling Fan
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Broken ceiling fan switch
home depot, Ace, true value cary rhem, probably better quality, doesnt sound like the one aloha uses are very rugged
Jan 18, 2009 | Aloha Housewares (93645) Ceiling Fan
Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
Nov 14, 2008 | Aloha Housewares (93645) Ceiling Fan
Speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Aug 06, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
21 people viewed this question
Top Dryers Experts
