Question about Akai PDP4225M 42 in. Plasma Television
TV>HD PVR 2>Xbox 360 Out of Range.
I have my Xbox 360 Elite connected to a HD PVR 2 this is then connected to my TV; It was working fine then one day it came up with the message 'Out of Range', it's all connected via HDMI, can someone help me.
3 Suggested Answers
  • 48 Answers
SOURCE: hdmi receiver to hd plasma tv
1. You cannot get and HDMI and component on one cable. One is anaglod, and HDMI is digital. Use the component, the difference isnt. They are both HDTV compatible signals. S-Video is terrible, its really no better than the old-fashioned coaxial cable. After you connect the two, be sure you go into the settings on your home theater and set the output to component, progressive scan, and the the resolution your TV supports. The resolution is clearly stated in the user manual and on the box. It is probably 720p or 1080i. (Dont worry, most HD devices will revert back to the settings if they dont work. So if it goes blank or you see undesired picture, just wait up to 15 seconds and it will revert your settings. Once you are successful, the menu will ask you if you can see the picture, use the remote to select yes.)
2. The remote came possibly with an auto scanning feature, but at least has a code entry mode to program
your brand of tv to work with your remote. Look at the list of codes based on category and brand in the documentation for the home theater system. Use all the codes available for your brand unil the tv responds to the code you entered. This is very brief but the manual has very specific instructions on what to press, step by step.
And the last question is absolutely yes, the picture is about 6x better than the regular tv standard which is 480i
480i is an interlaced picture, and its 320x480 dots of color to display your picture, interlacing is basically using one horizontal line to act as 2 by quicly alternating what it draws twice per frame. Thats why standard tv seems to "jiggle" in place
 Progressive Scan has a solid image, every time, that automatically doubles your quality. Definitely, you want your resolution to be as high as the tv supports and you will be satisfied.
Posted on Jan 07, 2008
  • 12 Answers
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Posted on Aug 28, 2009
Connecting xbox 360 to my TV
if your slim or elite or acrade consoles comes with a compenet hd cable or a hdimi cable inset 2 battries turn on your tv go to souce select scart or hdimi 1 turn on your console turn on your controller the setup wil apper hope that helps
Mar 28, 2013 | Microsoft Xbox 360 Console
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
Not working in hd with a hd lead connected but fine with composite lead connected
hi if you have the standard xbox360 and not the elite360 it will not work as the older standard xbox was not HD but the elite xbox is HD...hope that explains it for you
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 elite, no out put,blank screen ?
Make sure your connections are correct. If your using the HD component cable make sure the switch is selected to HD, if you have a HDTV or TV for a regular CRT tv.
HDMI, select the proper input on your tv remote.
Mar 30, 2010 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Akai PDP4225M 42 in. Plasma Television Logo
117 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
