Question about Ricoh Aficio SP C830DN - Printer - color - duplex - laser
How to access polygon mirror motor to check connection
Getting functional error sc202 on new printer
3 Suggested Answers
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 345 Answers
SOURCE: polygon mirror motor
Polygonal motor is inside the laser unit. You need a technician to repair this.
Posted on Nov 13, 2012
How to fix the error sc 20220
If the error you are talking about is SC202, then you have a laser problem. You will need to either replace the Polygon Mirror Motor or the complete Laser Unit if it comes as one assembly.
Jun 14, 2016 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
How do u repair sc202 ?
This is Polygon mirror motor problem.
1. Try to turn the main switch off and on.
2. Check the wires.
3. Check the polygon mirror motor PCB connector (bad, loose or broken)
4. Polygon mirror motor no good
5. IPU no good
6. Polygon mirror motor PCB no good
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
Where is the polygon mirror motor
You just bought it...take it back and exchange it for another?
Mar 13, 2014 | Ricoh CL4000DN Laser Printer
RICOH SPC430DN error sc202
sc202 is a polygon mirror motor. The most likely problem is that the motor has gone bad, and it will need to be replaced. Occasionally this error is caused by a loose or disconnected cable, but it is usually a bad mirror motor. You should contact your local service technician for replacement of the polygon mirror motor.
Nov 18, 2010 | Ricoh CL4000DN Laser Printer
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
Error SC320 appear on screen..
Polygonal mirror motor error change...
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP C830DN - Printer - color - duplex - laser Logo
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
