Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna 123l my trimmer starts fine but dies within a minute or two of full throttle...new plug and gas..ideas???
evwood
  • 50 Answers
SOURCE: Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Posted on Feb 14, 2009
  • 246 Answers
SOURCE: Husqvarna looses power after 10-15 min.
Hello Matt:
From your Description it Sounds like Either the Gas Cap is Not Venting the Tank, the Exhaust Port/Muffler is Restricted or the Rings are Worn Out and Require Replacing.
Make Sure the Gas Cap Allows Air into the Tank.
If the Gas Cap is Good, then
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then Most likely the Rings are Worn and Require Replacing.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 42 Answers
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna 323L gas trimmer runs & starts great
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Posted on Jun 07, 2009
  • 28 Answers
SOURCE: I have a husqvarna 125L gas trimmer and dies after
Could be clogged gas cap. Take the cap off and see if you can blow air through it. If no air passes, the trimmer will become vapor locked and wont be able to get enough gas.
Posted on Jun 23, 2009
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
My 123l husqvarna weed eater will start and run for a minute then shut off and if you squeeze throttle it shuts off
Is the choke leaver stuck in the on position.? Is fuel getting into the cylinder.? Also check fuel lines are not damaged
Apr 27, 2012 | Husqvarna 28cc Gas Line Trimmer
My brand new Husqvarna 128 ld trimmer starts and idles fine. Will not run at full throttlle. Either dies or just slows down. Half throttle seems ok. Its like it is starving for fuel. How do you adjust...
Husqvarna is a good brand, if you are having trouble with running at full speed there is something inherently wrong with your unit you do not want to keep it around, it will lead to more problems in the future. I would recomend that you return it and purchase a Stihl they are very reliable if you want a machine that stands the test of time. Even a Weed-eater brand from Walmart will start better than the one you have right now and you will pay less or the same for a comparable unit, That will run great! Good Luck...
Jun 11, 2011 | Husqvarna 28cc Gas Line Trimmer
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Trimmer puking gas out carb!
You could have a bad pump daiphram, which is holding the needle valve open. You can try rebuilding carb.or just replace carb. that is the easiest way.
May 16, 2009 | Garden
Husqvarna 28cc Gas Line Trimmer Logo
78 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
