Question about Ovens
Zanussi zkc5540 Fan oven not heating up, fan works and so does light
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens
if the oven fan and light are not working, then the clock probably needs setting. if oven fan and light work, but no heat, then the problem is probably the circular element round the fan. remove the back panel of the oven and you can often (but not always) see the damage. replacement of the element is straightforward
May 06, 2007 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
