Question about GE 13GP341 13" TV
Horizontal output transistor - GE 13GP341 13" TV
    Top Expert:
  • GE Master
  • 75,599 Answers
BU508D can be used.
Posted on May 02, 2013
A sansui tv switches on and off by itself. What could the problem?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Desolder out the horizontal output transistor, and now power on the set. If the set now powers ON, replace the horizontal output transistor. It is faulty. [Collector to emitter or collector to base leak]
Jun 26, 2015 | Sansui Televison & Video
Sansui sv29276
Replace all the capacitors connected to the horizontal output section. Especially capacitors connected to the collector of the horizontal output transistor.
Oct 16, 2012 | Sansui Televison & Video
I loss the horisontal regulator of my philips tv with 25pt463a/7ir model
Hello
You are talking about the horizontal output transistor damage I assumes and post this solution. If LOT has internal winding short, the horizontal output transistor will get shorted. It will be best to replace the horizontal output transistor, alongwith the LOT
Mar 03, 2012 | Televison & Video
When i turn on horizontal output tripping. B+ and low voltage ok
Hello
Check the LOT and Horizontal Output Transistor. If horizontal output transistor get shorted [collector to emitter or collector to base], this kind of fault will occur. Here there is nocollector to emitter short as B+ is ok. Check for collector to base leak. It is best to repalce the horizontal transistor with a new one, and switch on the Tv for a short while, say 10 seconds or so, and feel the heat of the replaced transistor. If it gets overheated, of LOT makes a whisiling of hissing sound, LOT is faulty, and shoul be replaced sith same type and number. OK.
Apr 17, 2011 | Sony PVM-14N6U TV
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Aiwa tv-14ST3 horizontal output always shorted
Hello
If horizontal output gets shorted always, something may be wrong with Line Output Transformer [LOT], or deflection yoke. If LOT windings inside is short, hrozontal output transistor will get overheated, and will be get shorted soon. If there is winding short in the Deflection yoke, even a sinlgle winding gets shorted, it puts a great load on LOT, which in turn effect horizontal output transistor. The third main reason for horizontal output transistor failure is due to an open or dry solder at the capacitor connected to its collector to negative It will be usually 2500pf to 3500pf, according to the TVs screen size. You just check these three and be sure about the fault.
Ok.
Oct 26, 2010 | Aiwa Televison & Video
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Oct 16, 2010 | Toshiba CX36H60 TV
KV-32XBR15
Yes, you should check other parts. The horizontal output transistor is more than likely shorted. Also the flyback could have gone bad. Some SONYs have problems with the horizontal driver transformer which is connected to the base circuit of the horizontal output transistor. If this little transformer has a loose solder connection, it will take out the horizontal output transistor. This may give you some insight as to where to look for your problem. Stargazer
Jun 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
GE 13GP341 13" TV Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
