Question about Canon Pixma MX360 Printer
Send fax is it possible for the phone and fax to be hooked up at the same time?
  • Canon Master
  • 32,281 Answers
With a single phone line only the phone or fax can work at one time but not both together.
Posted on May 02, 2013
My fax machine was working great up until this morning. I am able to send faxes but not receive them. The machine is hooked up to the phone jack and shares the line with our credit card machine. It is not...
It's entirely possible that your fax machine will just miraculously start working again. If it was hooked up to your computer you'd possibly be getting an error message, which when interpreted by its code number, would tell you it's not receiving the phone signals correctly for a period of time but soon will.
Hope I'm right,
Regards,
selk
Oct 18, 2010 | HP Officejet 6310 All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Problem faxing
Unplug the fax at the wall jack and hook up a regular phone. Listen to the dial tone. It should sound like a regular dial tone.
Next, plug the fax back in and call the machine from a regular phone.
You should hear fax tones.
Sep 07, 2008 | Office Equipment & Supplies
Sending faxes
You can hook a fax to any standard phone line. That is what they are designed for. The only issue is if you share the fax with your telephone, you will need to set the machine up to receive the fax before you answer the phone.
Jun 13, 2008 | Lexmark Office Equipment & Supplies
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Mar 20, 2007 | Toshiba e-Studio 350 Copier
Canon Pixma MX360 Printer Logo
old marine
old marine
