Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
My Danby model DBC2760BLS stopped cooling. Temperature reads 71 degrees and will not cool down. Do I need to replace the compressor?
5 Suggested Answers
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
drifterK
  • 4924 Answers
SOURCE: I have a Danby Silhouette
The device works like a refrigerator ..and there for the thermostat is to blame that it do not kick in the compressor once that the temperature exceeds the one that you preset ..So the action to do is to change the thermostat and will work fine ..
Posted on Dec 29, 2010
bobicehouse
  • 1524 Answers
SOURCE: Danby kegerator at 50 degrees.
How To Test the Compressor Relay Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor. Remove the compressor relay by pulling it straight off from the compressor.Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. bobicehouse_31.jpgThere are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Posted on Jul 14, 2011
imufo2
  • 3773 Answers
SOURCE: Danby all refrigerator model DAR1102W
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 10, 2011
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
Unit started beeping now is blinking HI and is not cooling
if compressor is hot to touch , let cool and change compressor relay.
Nov 09, 2013 | Danby DBC2760BLS (5 cu ft) Wine Cooler
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Unit does not cool when it is slid under the countertop. Temperature goes up right away.
Sorry to read about your problem, I hope this helps you out.
you must have lost the compressor cooling fan
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Danby DBC2760BLS (5 cu ft) Wine Cooler
Danby DWC513BLS does not cool. Fan is on, but compressor does not turn on to lower temperature even when temperature is turned down. Where does one get parts for this online
Before you worry about where to get parts,you need to know what is wrong and what parts you will need. When a compressor does not run but the fan motor does, then either the compessor is bad (in which case you need refrigeration expertise) or the starter components have failed ( in which case you can replace. The two most common failed parts are the start relay or the overload (both attached to the compressor. Goodluck, Macgivor
Jan 31, 2010 | Danby Silhouette DWC512BL Wine Cooler
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
106 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
