Question about Bradford White Bradford MIMS40T6LX 40 Gallon Propa
MIMS40T6LX installation instructions
Can you print the installation requirements for this water heater
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
How do I light the pilot
1) Open following link to identify type of gas control and read printed 'how-to-light-water-heater' instructions for each different gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Same printed instructions should appear on side of tank by gas control valve, and inside product manual.
3) Add a comment March 2013 and describe gas control valve.
Mar 13, 2013 | Reliance & 40 Gal Mobile Home Water Heater...
How can i install my hot water heater model 71-408 b
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Oct 25, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
Lighting instructions
More information is needed.
You posted under electric water heater.
Are you trying to light a gas water heater?
Each water heater is different depending on gas control valve.
Instructions for each gas water heater are printed on front of water heater at gas valve.
Add a comment and describe the gas valve, describe what the instructions say, and describe what general problem you are having for possible asistance.
Jul 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The pilot light on my hot water heater keeps going out
If you have a blower and electronic gas control on your AO Smith water heater, then reading the manual for your specific product is essential for troubleshooting the problem.
As you know, tank-type gas water heaters require periodic inspection and cleaning of burner parts and combustion chamber.. The manual is important for giving instructions and advisories to the homeowner and technical specialist.
If you have ordinary direct vent water heater with mechanical gas control the following link has some troubleshooting resources that might help:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 19, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
May 01, 2011 | Whirlpool Water Heaters
DIDNT GET INSTALLATION INSTRUCTIONS WITH MY E-75 WATER HEATER SAFETY STRAPS. ANY SUGGESTIONS?
1) Watts doesn't seem to have installation manual.
Page 7 on sales-brochure/manual shows your product assembled.
http://media.wattswater.com/F-Spcmkr.pdf
2) Add a comment for more free help.
3) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater straps or any do-it-yourself project. Give phone rep link to brochure/manual so they can speak to you about each individual part while you describe location of your heater and type of wall surface.
Jan 16, 2011 | Watts E-75 Earthquake Water Heater Safety...
Rheem 21V40-38 Gas - pilot light is on but when i turn knob to hot it does not do anything
Is the pilot knob turned to the "On" position? If the knob and temp dial are set in the correct position, you may have a recalled wtr htr which requires a retrofit "reset" button that needs to be installed. Call the manufacturer;s phone # that's printed on the side of the water heater and give them the model # and serial # and find out.
Douglas
Aug 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Bradford White Bradford MIMS40T6LX 40 Gallon Propa Logo
27 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
