Unlock carrier debonair 220 thermostat - Heating & Cooling
2 Suggested Answers
james3751
  • 614 Answers
SOURCE: blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Posted on Dec 03, 2009
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
Dec 14, 2015 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Carrier HVAC thermostat not fully displaying digital read out. Control bottoms doesn't work have to depress really hard and eventually works
Does it have a battery backup in the unit? If so replace them. If its an older model used frequently oil from your hands gets behind the buttons which causes intermittent connections and can cause display error. Remove the unit, carefully open it up and clean all contact surfaces with q-tip and a bit of rubbing alcohol. May solve your problem. While your at it make sure all wire connections are tight. Mark all wire locations during disassembly to make sure they go back in the right place.
Jan 01, 2015 | Carrier Heating & Cooling
Carrier debonair 400 won't heat
Hello my name is Willie of GMP mechanical services out of Centreville Virginia. I need some more Information about your AC unit is electric or gas heat. Is there a fault or fail signal in the digital display anywhere?
Jan 18, 2013 | Heating & Cooling
Why would a carrier bebonair 220 suddenly have a blank screen?
Could be the battery in the thermostat needs to be replaced. Or the transformer on the wiring from the unit to the thermostat has failed. The transformer is either an 18 volt or 24 volt model. It should be printed on the side of the transformer.
Hope this helps and thanks for choosing FixYa.
Sep 13, 2011 | Honeywell CT3600 7 Day Electronic...
Blank thermostat
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Creda debonair spin dryer lid not opening.
The lid had been fixed for delivery.Now it is opening OK thanks.
May 01, 2009 | Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
