Question about Garden
Robin fl500 Backpack Blower runs for a while 20 to 30 min. when you try to pull the trigger it looses power when you let go it idles
  • 68 Answers
SOURCE: blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
  • 4 Answers
SOURCE: blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Posted on Feb 05, 2009
  • 708 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Posted on Nov 03, 2009
  • 430 Answers
SOURCE: Ryobi backpack blower will run all day with choke
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Posted on Dec 13, 2009
FL500 Robin starts with choke on full but when the throttle is engaged it dies. I have tried mechanics in a bottle and Stable and ran it 30 mins on full choke with no change. help!
Sounds like you need to rebuild the carb. The gaskets stretch out and they won't pump enough fuel. Be sure to clean all of the parts if you do rebuild it as there is no use just doing part of the rebuild job.
Nov 05, 2016 | N2 FL500, Robin Back Pack Blower
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
Carburetor
either carburetor needs cleaning or check the Flame Arrestor on the muffler...they clog and engine can't Rev high
Sep 08, 2013 | Husqvarna 130BT 29.5CC Gas Leaf Blower...
I have a stihl br340 backpack blower that stalls
pull fuel intake line and blow through it to see if filter in tank is clogged, also the vent in fuel cap may be blocked up, try runnig it with fuel cap loose to check for this, if this doesn't help, prob gonna have to tear in to carb
Apr 21, 2010 | Garden
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
The trigger on my ryobi backpack is not functioning properly.
You need to buy a new cable, clarified by Ryobi Tech Support.
Jan 18, 2009 | Ryobi Backpack Blower 25.4cc
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Blower runs fine for 30 or 45 mins, then will not come up to speed.
Nov 01, 2008 | Homelite Consumer Products Backpack...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
