Question about Garden
Start engine replaced spark plug still will not start...model no. 247.37030...1 year old...bought as sears
    Loyalty:
    Visited the website for 30 consecutive days.
  • Garden Master
  • 1,211 Answers
Check for spark the coil may be grounded if not pour gas in chamber if it doesent start you have a fuel problem but check for spark first i feel thats your problem.
Posted on Sep 30, 2017
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: My 2 year old Yard Machine 21in 139cc MTD engine
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 03, 2010
SOURCE: Sears Craftsman mower-Tecumseh engine 3.75 HP-
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Posted on Jul 24, 2011
Stopped while driving cranks but won,t start replaced spark plugs and wires old plugs smelled like gasoline
"Old plugs smelled". Likely no spark. Coil packs, distributor, points (if your car has points), etc. If you share your car make/model/year/engine, somebody might have one and know where to look. Without that info, I can only guess.
Nov 06, 2015 | Cars & Trucks
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Craftsman riding lawnmower 141/2 model94467042 looking for a manual
www.google.com type in Craftsman 141/2 model or go to this website you will need the model name for it also. Sears, Allis, or Whatever it is?
Sep 19, 2012 | Garden
I am getting no spark at plug. Briggs model 31c707 motor. I have charged battery, adjusted valves, verified fuel line clear. Pull spark plug put into wire hold to motor and crank (no spark)
Hello, the next couple of things to check would be under the engine lid.
  1. Remove the screen over the air fan on the top of the fly wheel.
  2. Remove the 4 bolts securing the main lid and remove. Depending on the year of this engine it may have a secondary cover that Craftsman put on that will need to be removed first.
  3. When the lid is off you will see the magneto coil right above the spark plug; just follow the spark plug wire up to it.
  4. Use a wrench to see if the magnet on the fly wheel is strong. If the magnet is bad or really weak the flywheel will need to be replaced.
  5. Next check the magneto ground out wire. It will be a small black wire on the magneto. Unplug it then crank the engine. If the engine starts plug the wire back on the magneto and if it shuts down there is a short along the wire. It should only shut down or short out when the key is shut off. You will need to find the short if this is the problem.
  6. If the magnet is strong and the above test still fails to provide a spark then it is likely that the magneto is bad. You will need the rest of the model number; it will look something like: 31c707- # # # # - # # The part runs somewhere around $35.00 from Sears, but you might find it on-line cheaper.
  7. Replacing the magneto is pretty straight forward from there.
  8. Remove the old one and replace the old one adjusting it as far away from the flywheel as possible.
  9. Turn the flywheel until the magnet is directly across from the magneto.
  10. Put an ordinary business card between the magneto & the flywheel.
  11. Loosen the 2 screws that hold the magneto in place just enough for it to tighten up to hold the business card in place.
  12. Tighten the screws holding the magneto & rotate the flywheel to remove the business card.
  13. Test rotate the flywheel by hand a couple of full turns to ensure there is no contact with the magneto.
  14. Replace the small black wire, spark plug and spark plug wire, then test fire the engine.
  15. Shut the engine down and replace all the remaining parts in the reverse order as removed.
You should be good to go after this. If this was helpful please vote yes. Thank You!!
May 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 16 year old son replaced a 1980s Yamaha motorcycle 175 but it will not start. Thinks maybe something is grounding out? What do you think?
Hi, is this a points ignition or cdi, does he have a spark at the plug? An engine needs three things to run, spark,fuel, and compression, was the engine from the same year and model, maybe the engine has cdi, and the bike is fitted with a points ignition setup?
Feb 18, 2011 | Yamaha Road Star Motorcycles
Snapper 23 hp riding mower wont start.It sounds like it will start,but it never does.Battery is fine,everything is turning and making the normal noises,but it never actually starts.It is 1 year old,still...
CONNECT THE SPARK PLUGS TO THE HIGH TENSION LEADS IE PLUG LEADS,HAVE THE THREADED PART OF THE PLUG TOUCHING THE ENGINE, CRANK THE ENGINE OVER AND SEE IF THE PLUGS SPARK ACCROSS THE ELECTRODES IF THEY DO IT PROVES THAT THE ELECTRICS ARE OK.THE PROBLEM THEN IS EITHER FUEL OR COMPRESSION.ALSO YOU COULD SPRAY A LITTLE COLD START INTO THE AIR INTAKE WHILE THE ENGINE IS BIENG CRANKED,IF IT FIRES THIS WOULD ALSO RULE OUT ELECTRICAL PROBLEMS,IDONT RECOMEND THAT YOU USE THE COLD START OFTEN AS THIS CAN EVENTUALLY DAMAGE THE ENGINE.FINALLY PLEASE GET SOMEONE TO HELP YOU WITH THESE TESTS AND DONT TOUCH THE SPARK PLUGS WHILST THE ENGINE IS BEING CRANKED OR YOU RISK GETTING A SHOCK.HOPE THIS HAS BEEN OF HELP GOOD LUCK.MIKE WEBSTER.
Oct 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
213 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
