Question about GE JVM3670 Microwave Oven
Bulb replacement need to replace oven (inside) bulb in GE Profile Spacemaker microwave model JVM3670. Do I need to remove from wall to access the bulb?
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Posted on Jun 08, 2009
I found it helpful to remove the glass lamp cover (inside the oven) because the plastic cover plate arms protrude into the area where you are attempting to remove the lamp assy.
Also, the lamp assy has a plug connecting the power to the lamp which must be disconnected to remove the lamp. When this is unplugged there is no shock hazard associated with removing the lamp assy. - eliminating the need to turn off the power to effect the repair. General safety would still be removal of AC power to the micriwave.
Posted on Oct 11, 2008
I realize this is late but for other's here it is:
Posted on Sep 09, 2008
  • cdr94mpbn Aug 28, 2011
    The bulb..get it from Home Depot, ~ $5. Just replaced my bulb -too easy when you follow the previous post of instructions. Finally, the bulb has two pins - it does not/not screw out from the housing unit - plugs in.
  • GE Master
  • 9,173 Answers
Sadly, it looks like it. Some manufacturers are apparently making it this wayy to reduce their liability in case the customer gets cut or shocked. You can find helpful exploded view diagrams by selecting the option to look up repair parts here: http://www.geappliances.com/shop/prts/ The halogen bulbs must not be touched by bare hands. The oils from your skin will shorten their life.
Posted on Sep 23, 2007
  • William Miller
    William Miller Sep 23, 2007
    One more thing: Safety dictates that you unplug the oven from the wall before disassembly and consider this a two-person job. Be safe.
SOURCE:
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Where is the fuse located for the GE Profile Spacemaker microwave JVM3670?
Hello there:
if you first remove the power to the unit.
then remove the outer cover by removing the screws that are lovcated on the back and the sides the cover will come off then if you look at the right side looking from the front you willl see the electrical board and the fuse is on the board now take the fuse to a autozone or even radioshack and they will have this fuse ok
Hope this is very helpful for you
Best regards Mike
Oct 03, 2010 | GE JVM3670 Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace rack holder for ge profile spacemaker microwave JVM1490BD003
You can find helpful exploded views and order parts by entering your model number here
If the holder cannot be twisted & pulled from inside the cooking cavity, it may have a lock inside the oven.
If that's the case, it will require you to remove the oven from the wall and remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
May 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing interior light bulb for ge spacemaker xl1800
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
hope this helps dont forget to rate this
Sep 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Sep 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 23, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM3670 Microwave Oven Logo
1,011 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
