Question about Toro 51484 Lithium ion String trimmer, 12-Inch
Remove spindle toro electric trimmer
I cant remove the spindle on my Toro trimmer?
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
Posted on Mar 30, 2011
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
How to take off trimmer spool ?
the bolt that holds it on has left hand threads so turn it like you are trying to tighten it
Apr 04, 2012 | Toro Garden
Electric Toro Trimmer & I can't get the cap off to replace the string
I had a heck of a time trying to opwn the spindle case to get at the line. Tried all kinds of wrenches, etc. spent too much time at Home Deport (where I bought it) being sent from one sales person to another without any luck. However I went to Sears and purchased a Strap wrench- actually two that come in a package for like 12 dollars. One is larger than the other. I put the larger strap wrench around the bottom of the housing and the smaller one on the top part. The bottom one acted as a stable pivot put so it would turn counter clockwise and the top one so I could turn it counterclockwise. Worked like a charm.
Jun 07, 2011 | Toro& Electric String Trimmer
I cannot get more line out of my toro 15" electric trimmer. It cannot be empty, it has only been used once. The cutting line will not extend out any more. Should it not?
Sometimes the line can become fused together.remove the spindle and manually pull the line. Replace and the tap and feed should work fine.
May 12, 2011 | Toro& Electric String Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
Trying to remove part that fits on motor shaft.
Grab the bottom of the motor shaft with a pliers and the plastic part will twist off by turning it counter clock wise.
Jun 19, 2009 | Toro& Electric String Trimmer
Jun 03, 2009 | Toro Electric Trimmer
Toro 51484 Lithium ion String trimmer, 12-Inch Logo
22 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
