Question about Fisher and Paykel Aquasmart wl80t65c
Spin cycle causing load off balance
30 secs in to a spin cycle the bowl becomes very off balance to the point of hitting the internal shell of the machine. This stops the cycle and asks for the load to be re-adjusted. As it only happens with in 30 secs its doesnt allow the cycle ever to finish and i dont believe it has anything to do with the load. Any suggestions would be appreciated.
    Master:
  • 563 Answers
Unless there's damage to the machine it is the load. Make sure you aren't washing to small of a load. People do not realize how fast washers spin to extract. Just like they use tiny weights to balance your car tire, it only takes a little bit of weight to unbalance it.
Posted on May 02, 2013
  • 3 Answers
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Posted on Oct 14, 2007
juliankov
  • 13 Answers
SOURCE: F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Posted on May 04, 2008
  • 244 Answers
SOURCE: hi my smartdrive machine keeps going off balance
sure- hopefully you have a bit of room to move your appliance a bit. lay down on the floor, if able. use a flashlight. you should see 4 nylon or metal feet that the washer sits on. they'll have threaded bolts that lead into the bottom 4 corners of the washer. don't know how old your machine is, but if things look rusty, a little wd40 sprayed on them will help!
have someone help you lift the end of the washer opposite the way the axis of the drum is tilted. jiggle the drum a little and observe whether it becomes more centered. if you can, stick a piece of 2x4 , or 2x2 under that edge and turn the pads in a 'lefty-loosey' direction. this will raise one edge. take out the wood or spacer, and check the centering. you may need to mess with all 4 'feet', to get it right.
make sure your floor/platform the washer is on is solid!! if it's rotting out, check that your water connections are not leaking, and your drain hose is properly seated! good luck.
Posted on Sep 07, 2009
  • 410 Answers
SOURCE: My washing machine is stopping and beeps during
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
  • 713 Answers
SOURCE: fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Posted on Apr 24, 2010
Samsung washer keeps rinsing and draining and back through same cycle
Hi.
This sounds like the load is out of balance, and the machine is refilling to re-distribute the load. It senses the load during the beginning of the spin cycle.
It could be that the load is too small or that the garments have different density and water (weight) retention.
It could also be that the springs on the rods which support the bowl have sagged and have allowed the bowl to hit the out of balance switch. It could even be that the machine is rocking because the feet are not adjusted evenly..
I hope this helps you work out the problem.
Good luck.
Nomess
Feb 19, 2015 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Badly out of balance in spin cycle. When the machine goes to the spin cycle it vibrates and begins to walk. The machine will not balance the load small or large.
The legs underneath the machine become stuck from rust and corrosion. I had the same problem and all the repairman did was hit the legs with a screwdriver and it unfroze the legs and fixed the problem!!
Apr 19, 2010 | Maytag Ensignia MAV4757AWW Top Load Washer
Will Only Rinse/Spin with little to no clothes in drum
sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
Mar 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
If my washer machien makes a noise like boom boom and moveing what do i do get a part to fix it
The correct answer will depend on exactly what your washer is doing when the Boom boom noise is heard.
I will take a guess that it is on the 'spin' cycle or 'rinse' cycle - while the bowl is spinning. The boom sound is your wash bowl (drum) hitting the rubber bumpers located on 3 metal beam like parts.
The cause is either a bad balance in the load (lots of jeans bunched up on one side of the bowl throws is out of balance and it hits the sides. Or- one of the 3 springs that hold the bowl in the center of the machine cabinet is off its fastener. You can look under the machine (lay it on its face - on a towel or rug), with no water or clothes in it..... and check to be sure all the springs and fasteners are in place.
If one is broken, pull it out and take it to an appliance parts place in your area.... and get a new one. Just install the replacement part like the other 2 assembles inside the cabinet.
Let us know this does it for you.... -Jim
Oct 22, 2009 | Kenmore 22622 Top Load Washer
During the spin cycle the machine made a loud thud and now during spin cycles the machine pounds and slams yet when the machine is off the basket spins freely and without obstruction... any suggestions?...
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model #fwtr647ghs- It washes fine bu there is a clunking sound that happens on spin cycle, like somthing is being hit
Hi I am Vortash the most likely cause of your impact sounds are the drum as it hits the side of the machine on spin .. this is a result of an uneven load and the fact that the suspension springs for the drum and support rubbers may be worn . The load evens itself out eventually and the banging stops I assume , as the centralfugal force evens the load and the drum spin becomes more balanced . Replacement or tightening of the springs is adviseable but it depend how old the machine is as to the economics of this .. regards Vortash
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Violent and loud spin cycle Whirlpool Ultimate Care II
You may have one suspension point that has failed.
Open the back and using a flashlight, inspect the outer shell; the suspension should look the same at each point.
Don't know your particular machine but the suspensions are pretty primitive, some no more than heavy rubber rings at each point.
You're right that it shouldn't be ignored, as it can cause more problems and stresses the bearings abnormally.
Sometimes, this can be caused by running one very unbalanced load and not stopping the machine to redistribute the clothing to correct the imbalance.
This can cause a suspension point to become unhinged.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher and Paykel Aquasmart wl80t65c Logo
153 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
