Question about Panasonic Lumix DMC-F7 Digital Camera
Incorrect ac charger, digital camera doesn't work.
My son put my high voltage computer ac into the camera. It was working at first, but then it stopped. -Can you help me ???
I need charger for victor digital camara in kuwait need address
Posted on Oct 24, 2012
    Sergeant:
  • 390 Answers
Oh dear!!! Your son is very naughty!!! You should never connect cables or parts from another device to other devices not meant for them, unless they are a basic universal usb type cable etc. Most likely your son has fried a very delicate part inside you camera. It may well have worked at first, but many things will seem to work like that but eventually it will cause issues. Usually fairly quickly. The fried part may be small, like a connector or it could be a larger more exoensive part, unless it is still in warranty, you will either have to take it to a repair shop, and tell them the issue (high/incorrect vaultage leading to a possible fried part) or I hope you have warranty, and send it away. I would never suggest to another to open a camera but....I have fixed many cameras, but unless you are willing to have a go, it can be a bit daunting. I repaired a dvd this way. It turned out to be a fried part worth 30.00 but better than a whole new dvd. Never play with electrical stuff that is connected to anything and make sure not batteries are in!!!!
Posted on Aug 10, 2007
SOURCE:
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Can't get bushnell trail camera 8mp to come on
Use lithium (non-rechargeable) high energy batteries for best results. This is clearly a power supply problem. If it doesn't work, send it back for replacement. If the batteries are self-contained, ensure they are fully charged using the charger supplied with the camera. Remember, rechargeable batteries are only good for a maximum of two years. Cameras, in general, do not work well with rechargeable batteries as the voltage is less, i.e.; 1.25 volts vs. 1.5 volts per AAA/AA/C or D size battery.
Aug 27, 2012 | Acer Cameras
How to get a usb charger?
You can get USB chargers at a computer shop or on the Internet.
Here are 3 links to the Internet for USB chargers.
I suggest you get a unversal USB charger that can work in different countries with different mains voltage.
http://store.apple.com/au/product/TH404LL/A
http://cgi.ebay.com.au/USB-Charger-Universal-Travel-Adapter-AC-Power-Plug-/120464642889
http://www.amazon.com/USB-AC-MP3-Players-White/dp/B000A2BLEC
May 22, 2010 | Sony NWZ-S615F Walkman Video MP3 Player
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Samsung L730
My son has a Samsung digital camera and bought a Samsung SAC-45 USB Digital Camera Charger and a Samsung USB Data & Charger Cable Type4 SUC-C2.
He is able to charge his camera by plugging the cable into a USB outlet on his computer, but cannot get the camera to charge when using the SAC-45, which plugs into a wall 110 volt AC socket on one end and the cable on the other.
So far we have tried three SAC-45 units, keeping the same cable, and Samsung says they are shipping a fourth SAC-45 unit.
I think there is some problem with the cable, but haven't been able to get Samsung to send another cable.
Apr 06, 2008 | Samsung Digimax L730 Digital Camera
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery Wont charge
I have the DMC-TZ1. The charger is labelled "Panasonic DE-A25 battery charger". It has 3 contacts where the battery fits in. With no battery in place, the voltage between the top and middle pins is 2.61 V. The voltage between the middle and bottom pins is 2.19 V. Check those voltages. If they are very different from mine, I rather think the charger is not working. You can buy the batteries for very low prices on ebay from Hong Kong and other asian sources, but I've been told by someone who tried them that they do not work. Perhaps you have run into one of those. If you can find someone else with the same battery, a quick swap will tell you if your camera is okay. I got my camera on ebay and it works perfectly.
Jan 03, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
Panasonic Lumix DMC-F7 Digital Camera Logo
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
