Question about GE JGBP83WEJWW Gas Kitchen Range
F1 appears in place of clock display. Constant beeping sound accompanies. I shut the circuit breaker for 30 minutes as described in the manual . . . unsuccessful. What's next, short of a repair call.
    President:
  • 331 Answers
Amy, F1 indicates that your ERC (electronic relay control) OR your keypad has failed. Here is the test procedure to determine which... GO OUTSIDE AND SHUT THE BREAKER OFF!!! Open the top oven door (the model number you posted is incorrect, I don't know if it's a single or double oven but the procedure is the same)and look at the bottom of the keypad console. You'll see 3 screws under there. Use a 1/4" nut driver or socket to remove these. Then remove the control panel (lift and rotate toward you). From here, you'll see the back side of the ERC. Look for the green "ribbon" coming from the keypad and inserted into the ERC. Remove the ribbon cable from the ERC and let it dangle all by itself. Then replace the control panel in the reverse order from what I described above. Now turn the breaker back on. OK.... this is waiting period. Now that the keypad is disconnected you've isolated the 2 components. If the F1 error reoccurs, the ERC is the problem. If not, it's the keypad. The time frame for this diagnosis is 24 hours. If, after that time, the error does not show it's definitely the keypad.
Posted on Aug 09, 2007
SOURCE:
I have a mer5730aaw my bottom element dosen't work.Then the display showed F1 and started to beep.So I unplugged the oven and disconnected the multi wire to the control panel.Then it displayed F3
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 09, 2010 | Maytag MER5530 Electric Kitchen Range
We have an F1 error code, and cant get the oven to stay on...it sets for a minute, then beeps a few times, and shows a f1 code again
This simple test will help determine whether the ERC (Electronic Range
Control or Clock) or the touch pad is defective when F1 error code is
present.
as a single assembly, in which case this test is not necessary. Simply replace
the ERC (Clock).
performing this test or making this repair, please contact a qualified appliance
repair technician.
double check before continuing.
panel.
ribbon from the ERC.
back the way it was.
sound).
touch pad.
Dec 05, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Model JBGP80 MEV2BC Display panel shows "F1" and emits beeps (very annoying)... while unit seems now to be working fine otherwise. I will check and re-establish any cabling, etc. Meanwhile, how do I...
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Sep 16, 2010 | GE JGBP80 Gas Kitchen Range
Hi there: I am having problem with my stove. F1 is displayed on the indicator and there is a beeping sound. Do you have any solution. Can I repair it myself??
Sep 10, 2010 | Frigidaire FES367 Electric Kitchen Range
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
F1 error code and beeping on a ge doubleoven
Hello there:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Aug 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Aug 29, 2006 | Frigidaire PLES389D Electric Kitchen Range
GE JGBP83WEJWW Gas Kitchen Range Logo
64 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
