Question about Briggs & Stratton Garden
What's the cause of gas pouring out of carb on briggs&sratton edger
Will run but gas pours out carb
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
The float is open and letting gas get into carb need new float and valve
Posted on Jun 07, 2014
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
  • 376 Answers
SOURCE: no gas to carb on toro gts
Carb needs to be cleaned/repaired. Without knowing model number of the engine, that's all the info I can give you.
Posted on Jun 20, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
SOURCE: 13.5 briggs runs rough spits & sputters
13.5 BriggsandStratton ohv replaced push rod set rocker gaps ok now I do not have spark.
Posted on Mar 19, 2010
RonInFla
  • 86 Answers
SOURCE: i have a yardman 5hp lawnmower with b&s motor.
carb jet is clogged...B&S carbs require special tools...find a shop...
Posted on May 28, 2010
Briggs and Stratton easy start not starting easy LOL
Did you consider changing the carburetor?
Jun 13, 2017 | Briggs Garden
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
My briggs and steatton needs a part that goes feom gas line to intake
Given the very vague description, the only "part" in between the gas line and the intake would be the carburetor. If the carb is leaking gas and you have eliminated the possibility that your gas line is the culprit, then it is most likely a faulty float, or a stuck needed within the carburetor itself causing the bowl to flood and gas to pour out in to the intake and possibly even back thru the air filter assembly. These carbs are completely rebuildable and the float/needle can be ordered thru any Briggs & Stratton dealer. To a beginner removing and disassembling a carburetor can be hectic, so if you are unsure of your abilities, by all means either purchase the carb as a complete unit or carry the engine to a repair shop for service. Ball park figure on a complete carb can range from 65-120$ depending on make/model and seller. (Again, this is all based off of a very vague problem description so the carb may in fact NOT be the culprit- more detailed problem description can help us diagnose better)
May 30, 2014 | Parks Optical 13.5hp Briggs And Stratton...
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Air gap at the flywheel and coil on a 4 horse
Gap is .008 to .012. But use a brass feeler gauge.
Apr 22, 2010 | Craftsman 25cc Gas Line Trimmer
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
2001 john deere saber briggs moter smell gas in oil
If you're using ethanol-blended fuel, the ethanol will eat away at the neoprene parts inside the Briggs carb.Going to need a carb rebuild.
Don't run your engine until it's fixed or you could damage it as gas will pour into the crankcase, causing the oil to thin and lose its lubricating ability.
Sep 09, 2009 | Briggs & Stratton Garden
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
