Whjere is filter on intergrated candy cwb 1206 washer
Wont drain or spin
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Posted on Aug 31, 2008
mumma_1
  • 903 Answers
SOURCE: candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Posted on Jan 19, 2009
  • 10865 Answers
SOURCE: wont spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 20, 2009
  • 7 Answers
SOURCE: my washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Posted on Oct 29, 2009
How to make CWB 120 do extra spin
Turn off machine then turn control to spin position and turn on machine again
Nov 03, 2014 | Candy Washing Machines
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Candy washer cwb 741d pump does not work on a brand new washer
Check its plumbed okay hold hose over the sink to check operation of the pump
Feb 27, 2011 | Candy Washing Machines
My madhine will wash and rinse but will not spin
The problem here is the drain filter. Access the machine and clear the drain filter. Then check the machine.
Any further questions please feel free to ask.
Nov 17, 2010 | Candy CN136 Front Load Washer
Agitates but wont spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Candy CN146 Front Load Washer
When my washer gets to the spin/drain cycle (the last 20 minutes) it cuts off and unlocks. The machine keeps locking and unlocking and that's it. It will not move to the spin/drain cycle. What is the...
The filter on the front side of the washer was clogged. I have two children. So, I found candy wrappers, lip gloss, pennies. After cleaning the filter, it runs fine now.
Dec 17, 2009 | General Electric WCVH6800J Front Load...
Water wont spin out
open washer and check the DRAIN MOTOR PUMP , it could be clogged , inspect , remove any debris , replace and try again , AJ
May 20, 2009 | Candy AQ130 Front Load Washer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
