Sony flat wega 21 tv model kv 2199 xfj surqut
How to connect video and audio
  • 1694 Answers
SOURCE: Sony WEGA TV Model KV-32FS13 analog or digital?
No...your set has a digital tuner. Many of us will have a source
box for other reasons, such as getting sports packages or
movie channels......T.
Posted on Feb 27, 2008
  • 101 Answers
SOURCE: Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
Posted on Aug 27, 2008
SOURCE: sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Posted on May 01, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
How can change sony wega tv sound system from bg to dk/
Refer its user manual for details. You can select the system by entering its menu [sound]. Electro help
Sep 23, 2014 | Sony Wega Multi-System 21" Tv...
I have a Sony Trinitron WEGA TV 21", Model- KV-HP212M83, brought 4 years back and till now not a single problem. But today morning when I power on TV, it is not getting on. I checked all my power...
If your plug points are getting power, then follow as listed below.
Open the back cover carefully. identify the screws with a torch light, remove them.
You may have to remove two screws holding the audio video socket panel. This
is in the back panel. TV weight is on the front side. Hence guard it. By chance
by applying pressure on the screw driver it may fall off!!
Follow the power wire and check the fuse. It may have a small cover where the
fuse is secured. Remove the cover and take the fuse out.
Just view fuse in light. If the wires are parted apart, replace it. same type and rating.
Oct 08, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Does Sony FD Trinitron WEGA KV-21CL10 21" TV has a headphone jack?
Yes it does have a headphone jack. Lift the plastic door at bottom front center of TV to expose jack.
Aug 15, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No sound (sony trinitron kv-2197pf 21" tv)
try to short the spider transistor along ic amplifier. it is in a mute
Oct 05, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV SONY KV-21FV10C7
the tuner has three components in it. rf video, audio and carrier, so your sound is not seen at the separation of signals.
1 inject an rf of 5.5 Mhz on the rf in put, if the audio path is good a tone will sound at the speaker. if you dont have a sound then you should tune a coil drum on the audio separator stage.
the 5.5 Mhz is off frequency.
try that.
thanks for asking fixya.
Sep 02, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony KV-20FS120
Do you get sound when you play a dvd thru audio/video inputs?
If this unit has audio output at the back run audio to amp and see if you have audio thru your stereo
Jul 23, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
Top Televison & Video Experts
