Cerwin vega as30005
How much is a well maintained one worth?
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
SOURCE: Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Posted on Jan 31, 2010
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
What is the omhs of a cerwin vega avs sat4 surround speaker
According the the Cerwin Vega manual for this model and others, all speakers in the system are rated at 8ohms. This includes the Sat4 Surround Speaker and all other channels.
More information can be found at Cerwin-Vega's service and support page at: http://www.cerwinvega.com/product-manuals.html
You can also call them for information as well.
Mar 19, 2011 | Cerwin Vega AVS-5.1 System
I wanna know what the specs on this amp i just bought one recently
Cerwin Vega Vega-7000
2 x 175W @ 4 ohms (12V - 0.05% THD)
2 x 350W @ 2 ohms (12V - 0.10% THD)
1 x 700W @ 4 ohms bridged (12V - 0.10% THD)
http://ampguts.com/gallery/showgallery.php?cat=506
details and pics of cerwin amps on this site above.
Jun 22, 2010 | Cerwin Vega 2 Channel Amplifier - Vega...
Specifications of cerwin vega pro stax scoop sub
http://www.cerwinvega.com/pro-audio/portable-sound-system/int-118.html
You can always contact Cerwin-Vega and tell them the model number to get the exact info you need even on older models.
-Chris
May 25, 2010 | Cerwin Vega Pro Stax 12" 2 Way Stage...
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
20 people viewed this question
 Grubhead
Grubhead
