Question about Toshiba Satellite L505-S5988 Notebook
I need a schematic for L505-S988 as my touch pad and its key are not working!
Coffee was spilled on the laptop, no singes of liquid on touch pad board, all connectors are OK from touch pad to motherboard. windows recognize the touch pad in devices and if disconnected it disappears.
SOURCE: spilled liquid on laptop
If you have a systemguard warranty on your laptop better contact Toshiba Techsupport (1800-457-7777) and they will gladly send your unit for depot repair which is free to replace the whoule keyboard. No charges including Shipment and handling.
If you are out of warranty, you can dismantle the laptop KB and spray a contact cleaner on that might fix the issue.
Hope this helps
Posted on Jul 24, 2008
oropezae
  • 7 Answers
SOURCE: after cleaning for coffee spill dried up coffee spill my computer start well but i have touch pad unresponsive
You may want to open the laptop and check for damage to the touch pad including connection to the mother board. If you can not see any visible damage to pad or connection replace with another pad. Good Luck
Posted on Jun 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Touch Pad on my laptop is not working
Follow the guide below to tear the laptop down, you are extremely fortunate that the device is even working. Electronic sircuits and water have never been a good match, and your keyboard and touchpad are essentially just large electronic circuits. There is probably some water still somewhere under the keyboard and it is probably in contact with the tochpad cable or socket. When you have the keyboard off, use a hair dryer on warm and completely dry out all components and make sure all the small flat cables are tight in their sockets.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Posted on Dec 14, 2009
  • 17 Answers
SOURCE: Touch pad not working
just restart machine in bios setup ckeck that touch pad option is set to enable. and also check some of the laptop has one switch on keypad or on the top of touchpad for on/off utility is set to on
Posted on Dec 27, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshba Laptop L505-55984 CERTAIN KEYS DO NOT WORK
they keyboard is bad for sure, they make them so flimsy that the keys could be off. You can try moving your fingers back and forth on it from left to right in a sweeping motion to see if there are any stuck keys that could be affecting the keys.
If you do this and you have the same problems. Call Toshiba or the store you got the laptop from and get a replacement keyboard. Sounds like to me they used a refurbished keyboard on that laptop even though its new, companies do that form time to time and never tell the customer.
Posted on Jan 27, 2010
7ujm buttons stopped working
check to see if you spilled liquid on your keyboard. are the keys sticky that is a sure sign of juice of coffee spill
Jul 13, 2013 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
Spilled coffie on toshiba satellite l505-es5018 powered it off let dry opened it to look at damage not much on the mainboard but it wont power on when you plug it in to ac the fan runs as soon as u plug...
Anytime where liquid is introduced to a keyboard, witch is a direct input to the main board its without question that the main board would be effected. A main board has a BIOS Basic input and output system. When a motherboard shows sign of life with errors you would here some beeping. Whilst you hear nothing but fans so yes I would put my opinion on the main board.
Coffee most likely with sugar and cream, not all like it black. If this is the case or not the case its still liquid and a laptop is powered by a battery turned on or not. Anytime liquid touches a PCB board in layman's terms Motherboard your going to have damage.
Repair would be costly as you would need a new main board,keyboard shoot you might just want to purchase a new laptop at this point given there dirty cheap now days.
Thanks for the question, I hope my answer was Helpful, please do not forget to rate and leave feedback!
Thanks and best regards,
Rulds2008
Jul 27, 2011 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
Spilled water on my keyboard, touch pad stopped working. Dried it ff and left it for an hour. Unfortunately curser/ Touch pad still not working and can no longer connect to the iternet, seems like the...
When this happens, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Feb 26, 2011 | ASUS Computers & Internet
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Toshiba laptop keys stick
Could be some residue from a spill on the keyboard, or could be some old rubber thats not flexible enough. If you carefully flick a key off, you can investigate what's going on under there. The keys snap on and off rather easily. If you see anything sticky on there, use an electronics cleaner, or even some rubbing alcohol on a damp cloth or que-tip to clean it up. Recommend turning off computer completely and removing battery. And go easy on the cleaner :-), liquids and electronics do not play nicely together!
If none of that works, might have to start looking for a replacement keyboard for the laptop.
Dec 10, 2009 | Toshiba Satellite L505-S5966 Notebook
Touch pad
You probably fried something with the coffee.  There are replacement touchpads available if you know how to replace them if not an authorized dealer will be able to point you in the right direction.
Jun 02, 2009 | Toshiba Satellite Laptop with AMD Athlon...
After cleaning for coffee spill dried up coffee spill my computer start well but i have touch pad unresponsive
Jun 02, 2009 | Toshiba Satellite L355D-S7815 Notebook
Spill on laptop..how do I clean
ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
Jul 03, 2008 | Computers & Internet
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite L505-S5988 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
