Question about Electronics - Others
Free Hyundai Repair Manual
What does the sensor above the starter motor do that has red yellow and black wires can it be bridged that goes into the block
    Master:
  • 563 Answers
AutoZone . Com has free manuals available online.
Posted on May 02, 2013
2 Suggested Answers
  • 157 Answers
SOURCE: wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Posted on Nov 12, 2008
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1994
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Where is the cam shaft position sensor located 1999 hyundia sonata 2.5
Gary, Sensor is 3 to 4 inches above the starter motor on the V6
on 2.4 I4 engines the sensor is behind the timing cover if I am remembering correctly.
Service manual PDF
Download Hyundai Sonata 1999 thru 2014 Automotive Repair Manual PDF
Mar 20, 2016 | 1999 Hyundai Sonata
Have a ford f 350 2004 model manual ****** motor wont turn over replaced clutch safety switch ck starter relays can b pull started
Did you check for power at the starter ignition terminal? It is the small YELLOW/BLACK wire on the starter. If there is power there, replace the starter. If there is no power there, you should check your starter relay an its associated fuses.
The relay primary side is protected by fuse number F2.31 (15 Amp) in the Central Junction Box. This fuse provides power to the clutch safety switch on the WHITE/PINK wire. Then the power leaves the clutch safety switch on the TAN/RED wire and goes to pin 86 on the relay.
The relay secondary side is protected by fuse number F2.113 (30 Amp) in the Central Junction Box. It provides power at pin 30 on the relay, which is also located in the Central Junction Box.
Pin 87 at the relay is the YELLOW/BLACK wire metioned earlier and goes to the starter motor.
Pin 85 at the relay is the primary GROUND. This should be ground at all times.
The ENTIRE starting system can be checked/diagnosed from the pins at the starter relay if you use the correct methods and equipment.
Sep 11, 2011 | 2004 Ford F350
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 02, 2011 | Hyundai Motor 2003 Elantra
2001 sonata, engine died when turning corner and now has no fire from coils. Replaced coils, crank sensor and cam sensor. What else could it be? Thanx in advance.
If you have a faulty O2 sensor the PCM will not send the command to the coil(s) to fire, and if the PCM is faulty, then you will get the same issue. I would recommend that you start with the simplest thigs first and check the fuse panel in the car, and under the hood, then check the relays, and then the O2 sensor, and the PCM.
Mar 25, 2011 | 2001 Hyundai Sonata
I need radio color wiring diagram for 2001 hyundai accent what wire goes where
Battery RED (+) RADIO HARNESS
Accesory WHITE/GREEN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Apr 06, 2010 | Car Audio & Video
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
Electronics - Others Logo
47 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
