Question about Sportline 353 Talking Pedometer with Radio
Sport line model 353
I cannot find my instructions, and step length needs reset.
I was looking for the assembly instruction for this older model.
I was looking your other question about Classic Sport Triple Threat 222 portable basketball hoop assembly instructionsand couldn't find it on line so didn't answer it. But looks you was looking assembly instruction for that older model? Maybe you could provide the denimination for that older model
Jul 13, 2015 | Sport & Outdoor - Others
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
Brake line replacement/bleeding info
this might be more than you want to takle you can usually buy short lengths from part stores but if you need the full lengths you will need to buy it by the 25 foot roll you will need to double flange each side the parts store you are buying it from should asist I use oreillys then bleeding you must go furthest to the next furthest then down from that
Jan 15, 2014 | 1988 Chevrolet G20
Bought a tent with no poles no instructions have a model number
CONTACT MANUFACTURER FOR REPLACEMENT POLES ..OR # AND LENGTHS/DIAMETER OF POLES AND FABRICATE YOUR OWN...PERHAPS EVEN WITH SCHEDULE 40 OR BETTER PVC
Jul 30, 2012 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Singer Genie 353 manual
The owner's manual for this device is available for $15 from the Singer Support website at the following link:
http://www.singerco.com/accessories/instruction-manuals
Just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Then just type 353 into the MODEL NUMBER SEARCH BOX and then click on SEARCH.
You will then be directed to the online order page for that manual.
Good luck.
Joe.
Nov 27, 2011 | Singer Sewing Machines
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
Sportline 353 Talking Pedometer with Radio Logo
47 people viewed this question
Top Sportline Exercise & Fitness Experts
Tony
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
