Question about Dishwashers
Mdbh949pab top rack
Can I convert my MDBH949PAB Top rack into an adjustable rack?
SOURCE: TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Posted on Dec 28, 2008
  • 77 Answers
SOURCE: top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
Posted on May 13, 2009
  • 49 Answers
SOURCE: top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Posted on Sep 04, 2009
  • 2468 Answers
SOURCE: dishes on top rack don't get washed. Water
replace the wter conduit that runs up to the top and center spinner arms,after while these plastic conduit outlets get worn by water going thru them and leak past the o-rings installed on them
Posted on Apr 15, 2010
heatman101
  • 43501 Answers
SOURCE: dishes on top rack not getting clean. Actually
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Freezer door won't close tight
There should be adjustments in the hinge assembly. Go to Jen-Air .com, then select parts. They will have diagrams to view for repair, adjustment etc.
May 06, 2014 | Jenn-Air JCD2389G Side by Side...
Dishwasher top rack to adjust higher
There may be a wheel underneath the top rack, near the edge, which you should be able to turn and adjust the height.
Mar 03, 2014 | Whirlpool 24 in. ADG7540 Built-in...
Are the shelves adjustable?
The top shelf/countertop is not adjustable and it fixed at 33 inches high.
The lower two shelves are adjustable and can be placed at whichever height you desire.
Feb 16, 2014 | Seville Classics Bakers Rack Workstation...
Top rack rails came off the rollers
How to replace the adjuster on the top rack of KitchenAide dishwasher model number KUDS35FXSS1
Feb 03, 2012 | KitchenAid 24 in. KUDS01FLSS Built-In...
How do I lower the top rack?
Hello, Thank You for using FixYa. I will be helping you today.This model did not have the adjustable top rack. I looked it up and it doesnt show the option on this.If it did it would have two levers one on each side on top of the rack to raise and lower.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
How does the rack come out of the freezer to adjust
there should be a plastic clip between the rack and left side of the freezer remove the clip then push the rack to the left real hard then the right side should come out raise the right side up and remove rack
Jul 12, 2009 | Frigidaire FRT15B3A Top Freezer...
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Owen Barnes
