Question about Panasonic CT-34WX54 34" TV
Green Spot On Screen
I bought a ct-34wx54 tv second hand and it works great but it has a green spot on it i did the geometric option thing and it just moved the green spot around i also tried a heavy duty degausser and it didnt fix it either any advice? i hope the tube is not bad its just a slight green spot in top right hand corner other wise tv works great
  • 2 more comments
  • Quinton Otis Aug 23, 2007
    1st thanks for takin the time 2 help w/ my problem now could you explain how i would do or get a "fix one button magnet in the affected area" i am a not to sure what u mean and thanks in advance.
  • HiMan21 Feb 24, 2008
    I have the same problem, where I receive a green spot in the upper right hand corner of the screen after it's been on for about a couple of hours. What am I looking for if I take the back cover off the television to turn the magnet around?
  • Tribe Ningo Jan 31, 2014
    do you have any electronic gudgets battery operated
    dont place any gadgets near on your tv sets all with moving through electro magnets such as dynamoes and all things that have magnetic fields.it can affect the color of your tv set....at least have distance of 24 inches away from televisions
    New Friend:
  • 76 Answers
IN your statement says tv is second hand and also you tried degausser method also. The problem is permanent magnetic field affected your tv set. So the best recovery is fix one button magnet in the affected area.
Posted on Aug 23, 2007
  • Anonymous Aug 24, 2007
    Remove tv back cover. kept the tv in bluescreen position. In this position you found your problem. Just show the button magnet near the affected area you find there is a colour changes in screen. Rotate and fix the magnet where you find the screen full frame should be in clear blue. In that position phaste magnet properly. I hope that the above details helpful to you.
SOURCE:
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
May 07, 2012 | Panasonic CT-34WX54 34" TV
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with...
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Mar 16, 2011 | Panasonic CT-34WX54 34" TV
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
You really need to be persistent. I went on the Panasonic customer support webseite and started a web exchange. The first two attempts ended with "call your local authorized service tech" , etc. The third time, I described the prolem again and asked if the authorized tech would have the tool to fix the eprom if that was the cause of the problem. They finally gave me a name for their scheduling department and said they would pay for the diagnosis. I was pretty happy about that, but even happier when they said that this was a known problem and they would pay for the repair as well. They scheduled a service call. The techs came and fixed the eprom error with their tool within 1/2 hour. That was about 5 weeks ago, and all looks good so far.
Aug 27, 2008 | Panasonic PT-52LCX65 44" HDTV
SONY HD TV 60"
It honestly depends on what type of TV. If it's a sony 60" it has to be a rear projection model, if it was bought recently or in the last few years it would be a LCD rear projection model. Repair is not impossible nor out of the question. If the green spot is a color stain burned on the screen it's replaceable. However, the cost of a new screen and with installation can be pretty high. Even if it's the LCD projector it's still repairable. Cost could be around 700-1000 dollars. If thats considered to expensive to repair then the answer is yes. Even if the TV did cost more than that you can find some awesome deals on new DLP TV's not to far off from that price range.
http://www.bestbuy.com/site/olspage.jsp?skuId=8824301&type=product&id=1212191771968
View this link for a good comparison.
Have a great day
Aug 11, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
TV won't turn on
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
It could just be an expired TV.
Jun 24, 2008 | Panasonic CT-34WX54 34" TV
Panasonic CT-34WX54 34" TV Logo
437 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
