Question about GE Televison & Video
Horizontal # for GE tv - GE Televison & Video
    Top Expert:
  • GE Master
  • 74,666 Answers
MD1802FX , AND BU508D can be used
Posted on May 02, 2013
I have a 32" GE regular crt TV. Everything was fine and when I woke up the next day it would not turn on. Keeps making a clicking sound every few seconds like a solenoid trying to close..
Sounds like a probable shorted Horizontal Output Transistor (hot) Hopefully thats all. Sometimes the flyback will fail as well. If your not familiar with electronics I would recommend a tv shop repair. If its just the HOT transistor average repairs are 75-110 depending on your location.
Oct 17, 2010 | GE 32GT740 32" TV
31gt660 TV will not turn on. Makes high pitched sound.
This set has a shorted horizontal output transistor and possibly a bad high voltage transformer. If you repair the set, also solder the horizontal drive for the transistor listed above. Try www.encompassparts.com for parts. the h-ouput transistor is p/n: 223942 and the transformer is 223952 .Thanks and good luck.
Nov 07, 2009 | GE 31GT660 TV
My ge television just turned off. when I try to turn it back on it just clicks like four times!!!
These sets are famous for problems in the horizontal/high voltage circuit. Loose connections, bad high voltage transformers and shorted horizontal output transistors. If the picture was still good it is probably worth having it checked out. Thanks
Oct 10, 2009 | GE 32GT740 32" TV
GE Model 27GT600
If the TV is not connected in anyway to a HD cable or satelitte box that is incorrectly set then the TV has a horizontal sweep issue. There is no zoom or strecth feature on the particular chasis in your TV.
May 27, 2008 | GE Televison & Video
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Ge 32gt740 32 tv
please do not try to put it on for further damage.
buzz and sizzle and smell like all the wire were burning is due to short circuit in horizontal output section or high voltage flyback section.
please skilled tech to fix it.
it looks major problem but it is not a major.
can be rectified by skilled tech easily at your home.
good luck
Oct 17, 2007 | GE 32GT740 32" TV
31GT740
The GE (actually RCA) 31GT740 uses the CTC203 series chassis. The first thing I would do is resolder the coil on the base of the horizontal output transistor and the pins of the horizontal drive transformer, as well as any other solder joints on the main PC board that look weak or cracked. 9 times out of 10 that cures the symptoms you described. If you do not have experience soldering parts on PC boards then have a qualified tech handle it for you.
Jul 26, 2007 | GE 31GT740 31" TV
Ge 32gt740
The GE (actually RCA) 32GT740 uses the CTC203 series chassis. The most common problem in that chassis is a coil connected to the base of the horizontal output transistor comes loose, and the set may run sometimes and then it will shut off by itself. If you keep trying to run the set with the solder joints cracked on that coil then the horizontal output transistor will short out and the power supply will squeel when plugged in. Do not plug the set in if it squeels as this could eventually cause major problems in the power supply. The set needs a new horizontal output transistor and a good resoldering of the drive coil, drive transformer and all related parts. If you do not have experience in unsoldering and soldering electronic components in TV's then have a qualified tech handle it for you.
Jul 19, 2007 | GE 32GT740 32" TV
GE 35gt740-powering up and shutting off by itself
The first step is look for a small coil, L14401, one side connected to the horizontal output transistor and the other side connected to the small horizontal drive transformer. Resolder both pins of the coil and the 4 pins of the drive transformer. Let me know if that cures the problem.
Jul 07, 2007 | GE 35GT740 35" TV
GE 35GT168
If you indeed have a line down the center of the screen that means the horizontal output transistor is working as it produces high voltage as well. The rectifiers are working otherwise you would have no power or sound. What you need to look at is either the horizontal windings of the deflection yoke are open or you have a open return from the yoke to the horitontal output stage.
May 06, 2007 | GE 35GT740 35" TV
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
