Wilson paper shredder 1150
Does the shredder overheat when sitting idle?
3 Suggested Answers
  • 86 Answers
SOURCE: Wilson Jones Shredder Automatic On/Off
When auto function does not work there are two things to do 1st. canned air is your friend try blowing out the photo sensor that makes the auto function start. It is located in the very center of the feed point upper and lower parts meaning two areas to clean. they usually are little round spots when paper dust gets on them they either continuously run or do not run. Now 2nd if cleaning does not help then you may have bad photo sensor. you will need hands on tech. respond if having trouble and leave feedback if this helps. Have a nice day!
Posted on May 13, 2010
sg1972
  • 225 Answers
SOURCE: shredder says service due. cannot clear display
Clearing the "Service Due" prompt:
1. Lift safety flap (plastic cover over paper entrance).
2. Depress Reverse and Stop button simultaneously 2-4 seconds.
3. LCD display reads, "Service Info 1"
4. Press Stop button once to obtain "Service Info 2"
5. Depress Forward and Reverse buttons simult. 2-4 seconds.
6. "Service Due" prompt will be cleared and service hours zero.
7. Snap safety flap down to close.
Posted on Aug 05, 2010
My 17 year old Wilson Jones 1153 Model shredder can't be left plugged in-It drains the electrical circuits and turns our heater off. Other than that,it works great.Is this worth repairing-Suggestions?
Just take it apart and unplug the switch that is keeping it on. take pictures when you pull apart the cases. sometimes some of the screws are under labels. Should be no more than five screws. Paper has an oily presence and causes these type of failures.
Apr 18, 2017 | Wilson Jones Office Equipment & Supplies
Our Wilson Jones 2000 shredder is jammed. I put too many papers in it at once, didn't realize they were folded on the bottom. How do I clear the jam?
Try reversing it. If that fails, get access to the shredding mechanism (with power off) and pick the paper out piece by piece and bit by bit.
Oct 21, 2016 | Shredder Office Equipment & Supplies
Shredder is Wilson Jones 130 auto. I believe staff shredded to many sheets at one time. No no lights no power forwards or backwards. Is there a reset or fuse, can't find one
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
Jun 21, 2011 | Office Equipment & Supplies
I would like to know how to oil an Wilson-Jones 1250 schredder.
Wow, a name from the past.... with any shredder the easiest way to "oil it" is just to put a bead of oil in an "S" pattern down a sheet of paper to be shredded and then shred the sheet of paper.
If you shred a lot you should do this more frequently...if its only occassional shredding OR if its a strip cut shredder then you don't have to do this as often.
Jun 16, 2011 | Office Equipment & Supplies
I have a new Office One paper shredder VS502C and it has stopped working. Do you have any suggestions
these machines overheat when you shred paper constantly let it cool down for 20 mins,or the top part of the shredder might not be properly placed,lift it up and replace it again.
Feb 15, 2010 | Shredder Office Equipment & Supplies
Jan 20, 2010 | Office Equipment & Supplies
Paper Jam in Wilson Jones 1500. Reverse doesn't clear it. Is the plastic cover where the paper is fed removable?
You should probably unplug it. Two screws in back and under. Slide front cover back an inch.Disconnect cable and clean unit with vacuum.
You can hand cycle it in both directions to loosen up the blades.
Aug 12, 2009 | Office Equipment & Supplies
Need forward & reverse plastic key buttons
Spray some contact cleaner into the buttons and this may free them up. try this
Apr 15, 2009 | OfficeMax 0M96431 Shredder
Shredder says service due. cannot clear display
Apr 06, 2009 | ACCO Brands Office Equipment & Supplies
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
110 people viewed this question
jasbo
jasbo
