Question about Roland Vs-2000CD Digital Studio Workstation System
Initialization Hi i've got a problem with my vs not starting up from the initialize screen,it say's that my IDE,HD,CD is ok but it wont start or boot up or load from there,it useto fine!is there a combination of buttons that i can press on start up or something else i could do to fix this problem?please help me as i have searched every where and looked in all my manuals i can't seem to fix the problem.Thanks hear from you soon i hope!Gabriel.
  • 1 more comment
  • Gabstar Aug 10, 2007
    Hi thanks for the help but it was unuseful as i clearly stated that the unit won't initialize and i cannot even get to the display screen,i think the problem was from improper shut down like i said it says that the IDE,HD,CD, is ok but won't load up from that screen!i've looked in all manuals and tried everything but it won't even let me into the display,if you could help me further it'll be much appreciated thanks Gabe!
  • Gabstar Aug 13, 2007
    Hi i really have to say that the info that you gave me about updating the system through the roland web site was the most useful i've got from anyone and yes it did fix the problem!!! and i am very greatful to you and fixya for the solution,i hope down the track if i was to have any other problems with the vs 2000cd you are there to help!!! i thank you very much and hope you much luck in life for helping me and others!Gabriel.
    President:
  • 1,114 Answers
Are you able to access the utility menu by pressing shift & F4? If you can then: 1. Press UTILITY. 2. Press PAGE until ?PrmIni? appears above F1. 3. Press F1 (PrmIni). 4. Turn the Time/Value dial to select: ? MIXER & UTILITY ?to initialize both the mixer and UTILITY parameters. ? MIXER ?to initialize only the mixer parameters. ? UTILITY ?to initialize only the UTILITY parameters. 5. Press F5 (OK)?a confirmation screen appears. 6. If you?re sure you want to proceed, press ENTER/YES. To cancel the operation, press EXIT/NO. This should restore the factory default settings.
Posted on Aug 09, 2007
  • 1 more comment
  • Greg Cann
    Greg Cann Aug 10, 2007
    OK two more things you can try.
    I have found the following procedure to reset:
    1. Press and hold both snare 2 and FX2 as you are turning the power on.
    2. The system should now boot up. To format drive, hold shift and press F1 which will take you to the project list.
    3. Press the page button three times for ?FMT DRV? and press OK. Then follow instructions as they appear on the screen.
    If this fails then try a system update from a PC or MAC the update files & readme can be downloaded from Roland's website below:
    http://www.rolandus.com/products/product...
    Good Luck!
  • Greg Cann
    Greg Cann Aug 13, 2007
    Hi Gabriel, did you get a chance to try my latest suggestions to reset the Vs-2000CD yet?
    Please update the question & let us know if the information given was useful to you - Good Luck!
  • Greg Cann
    Hey that's great news, thanks for the feedback.
    Perhaps you can update the question to solved for me?
    Best regards,
    Greg.
Ok, i had an IDE HD of Maxtor. Now i just bought a SATA one from SAMSUNG. I want to make the SAMSUNG to be the master and the Maxtor Slave. Jumped the Samsung, removed the jumper from the Maxtor. Now, to...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
??????????????????????????????????????????? hope this helps
Dec 27, 2010 | EliteGroup ECS 945P-A...
Brought acer travel mate back to factory using recovery discs now it wont reboot.I put discs back through with no result
Check the bios settings, in boot settings you must set CD unit as first boot device, then you start PC with recovery disk 1 inside.
Sep 05, 2008 | Acer Computers & Internet
On start-up, (from HD or CD) I get the Apple, then "unable to fin
This is the message you see when a version of OS X has been installed on a Mac that needs a later version of OS X at minimum, or when the custom gray install disc for one model of Mac has been used to initialize another model of Mac.
You posted this under "iBook G4," and the platform in the error messages says "PowerBook." Provided you posted in the right place, that confirms the above diagnosis.
Initialize your iBook with the proper gray disc, or a retail OS X installation disc, and it will operate properly.
Nov 13, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Dell 8400 e210882 .hd on ide pri .error initializing pci express nic bridge. drive 0 not found. drive 5 not found.the hd is seen on drive 4,and tests ok.flop. and cd rom off in bios. where do i put ide...
When installing hard drive much sure that the jumpers are set to primary position or ds master on some drives. Make sure they don't conflict with other drive or cd rom.
Now if having issue with bios error download the lastest bios update and run it. If not sure ask a friend who has do it before and get some help. The error sounds like a bios upgrade is required to solve problem. Let me know how you go.
Mar 19, 2009 | Dell (E210882) Motherboard
Hitachi 400GB internl drive not seen.
Initially, pls :
  • check/replace IDE cable used;
  • check power connector;
  • verify master/slave jumper setting;
  • reset CMOS/BIOS to default;
  • change motherboard IDE connection from IDE1 to IDE2 or vice versa;
  • try as a standalone, temporarily remove any other IDE device such as the DVD/CD.
If all else fails and thee HDD works/checks OK in other machines, you may need to update the BIOS of the Asus A8V deluxe. Pls start here. Click on "DOWNLOAD", on the :Input Model to Search" type A8V, in Select Category, choose BIOS, click on Search Info button, follow on screen instructions
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
CD-RW not working on same Ide cablew as HD
Hi, please check the power connector to the drive. if it is ok, restart the pc, enter BIOS setup, check whether the drive is detected or not in the drive configuration. if not there, check the jumper settings once again. for the new motherboards with one IDE and SATA interfaces, jumper settings are important. once i had the same problem.
good luck
Jun 22, 2008 | Computers & Internet
Hd for hp nw8000 laptop. pn:345855-001
yes u can it depends upon the size of the hdd
it starts from the price range of 80$ go bestbuy
May 22, 2008 | HP Compaq nw8440 Notebook
Help?
Perform a system update as per the link below: http://www.rolandus.com/products/productdetails.aspx?dsection=d_downloads&ObjectId=602 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 19, 2007 | Roland Vs-2000CD Digital Studio...
Roland vs 2000cd studio workstation/harddisk recorder.
I have figured out a way to get around this problem without losing your data or sending it to Roland. I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
Aug 10, 2007 | Roland Vs-2000CD Digital Studio...
Roland Vs-2000CD Digital Studio Workstation System Logo
174 people viewed this question
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
 Grubhead
Grubhead
ka4iup
ka4iup
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
