Question about HP Photosmart 6510 Wireless e-All-in-One Printer
Paper tray won't go in
There are rollers strip stopping tray from going back in
4 Suggested Answers
Patrillica
  • 141 Answers
SOURCE: error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Posted on Apr 02, 2008
M D NAVEEN
  • 72 Answers
SOURCE: I have an HP 8500
it touches the tray according to he size needed so if u want in the second tray can keep the size greater then a4 and chnage the settings so it takes from the second tray .................
Posted on Oct 27, 2010
vinay229229
  • 1121 Answers
SOURCE: HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Posted on Jan 23, 2012
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 15, 2011 | Office Equipment & Supplies
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Paper jams. Get a lot of these when running multiple prints of the same file. Paper puckers up and jams when the print heads start to draw. Have tried different vac settings and no changes
Kindly let me know the make and model of your printer alongwith what type of paper you use and also does it stucks when printing in black and what mode or color mode.
May 24, 2011 | Office Equipment & Supplies
When I try to print a page, printer does not pick up paper and then gives error message that printer is out of paper when there is plenty of paper in the tray. Sometimes if the printer hasn't been...
Hello.
From the HP site:
There could a problem in the pickup assembly area of the product. There are twoblack Mylar light shields approximately 3.5 inches long. They are located onboth sides of the pickup roller under the pickup roller rod. One or both ofthese black Mylar shields can be tucked under, or partially bent when removinga paper jam from the paper input tray slot.
Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity until the fingertips reach the end of the cavity.
4. Bend fingers up to push theblack Mylar light shields back into place. The proper position of the blackMylar light shield will be flat.
5. Reconnect the power cord.
6. Print a self-test/configuration page to verify product is functioningcorrectly.
If still a problem, make sure that the tray, paper is locked in thecorrect position. Sometimes the spring in the tray can become worn out andloose. You can take that out and spread it out a little. Also, make sure thatthe tray bottom is free to move. Take out the paper and see if it goes up anddown correctly. If you don't hear the pickup roller moving or the motor runningyou may have a bad feed roller gear. There also, could be a problem with thepickup roller.
Hope this helps.
May 23, 2011 | HP PSC 2355 All-In-One InkJet Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
My printer keeps stopping miod way through printing or saying no paper when there is
Hi it normally just means the paper in the tray was not picked up by the machine.
Remedy remove the paper and tray get a soft cloth with some methylated spirits on it and wipe over all the feed rollers including the ones at the back.
if no meths try a damp cloth (its not easy to get to the rollers in the paper tray but you can without the need to strip the machine
If you found this useful please rate me thanks ian
Mar 10, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Does not take paper
If the printer won't "pick" the paper, open the back of the machine and look for torn pieces of paper obstructing the path. The paper should be all the way back against the stop so that the rubber rolls will contact the paper when the paper is lifted up against them. There should be no paper bunched up behind the access door. If the paper is against the stop at the back of the machine and the rubber on the roller wheels is ok (mine has three rubber rolls on the right side and one on the left plus a couple in the middle without rubber) then there is a possibility that the mechanism that moves the paper up against the rollers is not operating. You can observe the paper action with the back off by putting one sheet of paper in the tray. Watch as you press and hold the second button (paper) - the mechanism should lift the paper up against the rollers and feed the sheet out the back (because you have the access door off to view). If the paper is not lifted and taken out, the printer might be repairable by repairing the part that has failed - take the printer apart and look at the mechanism. I doubt that you can find parts for it so if it is not simple repair, it will probably cost too much to repair. The paper has to be far enough into the tray so that the rubber rollers catch it - for 8.5x11 paper, the paper should be a little over an inch from the forward edge of the tray when it hits the stop (the paper guide will be approximately 1/8 inch in from that same forward edge.
Jun 09, 2010 | HP DeskJet 810c InkJet Printer
Have 1700 that picks up paper then stops after pick up
We use these printers in the computer labs at the school district I work for. The easy inexpensive fix is to turn the rubber bands on the rollers inside out.
Sep 21, 2009 | Dell 1700n Laser Printer
HP Photosmart 6510 Wireless e-All-in-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
