Question about Acer Aspire Z5761 23" All-in-one Computer 4gb/1tb Intel I3-2300s Windows 7
Acer aspire z5761
My cpu keeps on freezing and shutting down doing simple tasks like watching youtube videos, also sometimes when i start it up screen stays blank and a continous beep and i have too shut it down straight away
kyo_ajis
  • 68 Answers
SOURCE: Blank Screen Acer Aspire 5920
im afraid that your screen is broken, but try to move the screen foward and backward littlebit, my friend also have the same problems and only by contact local support using his warranty the problems fix, you may open your laptop to see if something wrong with the wire but i think its not practically good.
Posted on Jan 28, 2009
babes_ganda0
  • 381 Answers
SOURCE: Aspire 5315: Loud, Long, High Pitch Beep During Start Up
you need to replace the memory..or try to make clean using a Paper Eraser for make a clean the memory..clean the all pin connectors..good luck
Posted on Jun 25, 2009
n5kb
  • 349 Answers
SOURCE: my acer aspire 5738g keeps shutting down when i'm
Sorry you are having troule. It sounds as if it is getting hot and protecting itself. Games are very cpu intensive and this causes heat. The cheap fix is an under cooler. This is a cooler the laptop sits on. I have seen them at Best Buy for under $20
Posted on Apr 08, 2010
  • 66 Answers
SOURCE: my acer aspire l100 keeps shutting off. it
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
Posted on May 15, 2010
nilutpalsono
  • 238 Answers
SOURCE: have a acer aspire 5520,it
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Posted on Aug 21, 2010
Acer Aspire z5761 recovery disk wanted
You can contact Acer tech suppot and get the discs. It's cheap.
Oct 11, 2015 | Acer Aspire Z5761 23" All-in-one Computer...
Why does my acer aspire z5761 keep freezing and has horizontal lines across screen and constant bleep?
You probably somehow killed the screen. Did you drop it or bang it into something? You can try downloading and replacing the drivers, but I doubt that will help. Lines on the screen are usually a physical problem, not software related.
You may try a Windows Restore if your machine has that ability. Some do, depending on who you bought it from. Again, doubful it will help, but worth a shot.
Need more information on the bleep. When does it bleep? Constantly? When you touch the screen? Or when you boot it up? What kind of bleeps? One? Several? Long? Short? Both? Repeating sequence?
Jun 28, 2015 | Acer Computers & Internet
Freezes
I had an acer aspire 5335 that did the same thing, do as I say... CTRL+ALT+DELETE and open task manager. got to processes. Id there are many of them from programs you don't have or don't recognize you could have viruses or unneeded processes. try ending them, they usually never close by themselves and require you to do it as said. they could be slowing down your computer to this point. If not then watch the performance on idle with no tasks running. if the cpu is jumping from a low number like 10% to 80%-90% non stop you might want it to be checked out.
Dec 24, 2013 | HP Pavilion dv6-6c00 DV6-6C40US A6Y50UA...
Acer aspire 5520 keep shutting down also will not start
Well, I know the solution to your problem...But I'm not going to tell you!!
Just kidding...
Problem: CPU becomes very hot as result laptop shutdown.
What is the solution then?
Simple, just remove the dust from the cooling mechanism by the fan.
Dec 27, 2010 | Acer Aspire 5520-5908 Notebook
I have an acer aspire 3680 laptop with a broken power button
Ok, it seems that this is a pretty common issue. I found a youtube video showing how to get around this. I watched some of it, the guys seems pretty competent. however, you might not be comfortable taking this thing apart or doing what he is doing. However, it is a relatively simple thing to fix for a competent repair person and I looked up new power assembly and they run around $25 on ebay. Here is the link for the video I found:
https://www.youtube.com/watch?v=YMprUUBvlmo
There were a couple of other videos also that I didn't watch. However, if you just need this thing to work for a while and you intend to replace it in the near future and just need to get by for a short while, this should work. If you intend to keep this long term you might want to take it to a computer repair shop. Good luck. hope this helps.
Sep 27, 2017 | Acer Aspire 3680 Laptop
My 4 year old Acer Aspire 5520 notebook shuts off on me at random time periods. I try keeping it proped up and keeping it cool but that doesnt even seen to help. It doesnt over heat but just decides to...
Have you cleaned the cpu fan? The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. The other thing that could be happening is some problem with windows, which is something I couldn't begin to guess. Hope it's just a bit too much heat.
Mar 29, 2010 | Acer Aspire 5520-5908 Notebook
Aspire One start problem
Here you go
http://www.youtube.com/watch?v=l6GRhsvP-og
get a flash disk and watch the video
this video explainn how to fix bios on the black screen
although yur screen shows the acer logo yu seem to be experiencing some bios trouble
So do the above
Jan 10, 2010 | Acer Aspire One PC Notebook
Acer Aspire 6920G T5750, processor too slow?!? Games freeze!
looks like you have enough ram and a good video card ... maybe try this http://www.iobit.com/gamebooster.html
just down load and run this when you play your games... make sure you turn it off when your done playing games
Jun 23, 2009 | Computers & Internet
Laptop stalling / CPU overload
Sometimes the best solution is to save to disk the important things and just reinstall everything.
Jan 17, 2009 | Acer Aspire 3610 Notebook
Acer Aspire Z5761 23" All-in-one Computer 4gb/1tb Intel I3-2300s Windows 7 Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
