Question about HP DesignJet 3000cp InkJet Printer
Not printing my printer is conected true USB. when ask to print the printer conects to computer sayns its loading and the light flashs but nothing happens and gpes back t ready
  • adi silveira Aug 10, 2007
    There is no error messages,, it just go back to "ready" and nothing happens. and yes its connected to a usb
    Sergeant:
  • 390 Answers
Do you mean your printer is connected to a usb port at back of computer? Obviously it must be or no communication would occur!!! What error messages are you getting?
Posted on Aug 10, 2007
SOURCE:
New printer won't print
When you install a printer, you should conect it to power, turn it onand follow installation instructions. you must have at hand the USB cable. Most printers ask to install first the DRIVER in the computer, then they ask you to connect the USB cable
Without knowing more about your printer, there is not much more I can help you
Mar 12, 2015 | Office Equipment & Supplies
Document failed to print
There are some printer order pending in your computer. For these reason you may to remove printer order. To cancel print order follow these proces
Start - printer and fax> printer icon double click> show window> then delete print order.
Now unpluge all the conection both usb and power. Wait few minites, and then reconect conection again
Thank you.a
Now , op,
May 19, 2011 | Office Equipment & Supplies
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
Printing from 2 differant computers.
At the same time,,no,u have to either use the parralel port or usb at one point of time
this printer was actually launched when the transition just started,,usb printers were new and the parrallel printers were already in use..so its like a backup,,if parrallel port on ur comp doesnt work,,then use the usb
best of luck,,giv a good rating,,keep me posted
May 19, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Problems printing on HP 1220c using vista
1.make sure printer is in ready condition(lamp indicator not blinking) and conected.if blinking thers problems with printer ,catridge or something
2.contrlol panel>printer chek status of printer.if 'offline' its not properly conected.if 'ready' then>
3.download hp diagnostic tool from hp website and run it.it will detect the problem and follow the instruction.if not work>
4.uninstal driver and printer,reinstal it.if not work>
5.try on another comptr.
Mar 04, 2009 | HP DeskJet 1220c InkJet Printer
My printer will not connect for printing a letter or spreadsheets
Has it ever copied properly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
No printing
has your copier been set up with pin numbers or department counters, if so you will need to enter a valid pin no. in printer driver properties. Also go into printer properties and check printing preferences aswell as properties for any paper size/tray issues and remeber to apply any changes.
Mar 05, 2008 | Office Equipment & Supplies
HP DesignJet 3000cp InkJet Printer Logo
113 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
