Question about Ovens
Hotpoint ew 72 slot in cooker
Top grill in top oven only one side coming on
5 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
SOURCE: i have a hotpoint ew 52 cooker and the grill does
I've an EW 71 with exactly the same problem! Thought it was the element but then noticed that there were two elements to the top oven - so very unlikely that both would go at once.<br />Tested to see if the switch was the guilty party by turning it on using the upper oven switch and indeed both elements heated!<br />If yours is doing the same then it's the switch....<br />... So how does one replace the switch?<br /> <!-- from fixya rte -->
Posted on Aug 15, 2010
  • 14 Answers
SOURCE: the grill on my Hotpoint EW 41 Electric
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Posted on Jun 12, 2011
Testimonial: "thanks for that mate"
How do you replace main oven temperature indication light for hotpoint double oven cooker model ew 74
In doing a general google with the brand/model, there are many things that come up about issues. You need to contact http://www.geappliances.com/service_and_support/contact/form_email.htm. They state their product is backed by GE. Many places sell this, but look for one with GE products. You might have an appliance store close by with that information.
Mar 06, 2014 | Ovens
Top oven not working in a hotpoint dh53ck
change the thermostat and check.
Nov 07, 2013 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
Jun 12, 2011 | Hotpoint Ovens
I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
Aug 07, 2010 | Hotpoint Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Sep 03, 2009 | Ovens
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
