Question about Frigidaire FWTR445R
Year old frigidare washer won't agitate
The washer fills up fine but won't start to wash the clothes. I can manually advance it to spin cycle and it will spin just fine. then will fill up to rinse and just sit there. I checked for loose or burnt wires but didn't see any. there is no motor hum or anything after it fills up with water
  • Anonymous Mar 17, 2014
    Initially thought the washers timer was the problem because it wouldn't advance without manual intervention
    Problem Solver:
  • 9 Answers
The selector switch might be out.
Posted on Dec 23, 2007
SOURCE:
Washer won't advance, have already replaced the timer. We can manually advance it but that was the whole reason for replacing the part. Lid switch is fine, will fill with proper water level, will spin and...
Hi iv acidently washed a poise pad in the washing machine ,,the pad broke open and a gel like substance is all through clothes is this toxic,,is it silicone?? what if we wear cloths will it be absorb in blood system if we wear them im stressed as gel filled whole washing machine,,and dont know if clothes are safe to wear,,i cant find any info on wether poise gel in pads is dangerous plz help arrgghh
Feb 08, 2014 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
161 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
