Question about Nikon Coolpix 4600 Digital Camera
Error 10 message
Hi! i have got a nikon coolpix e4600 camera. yesterday i wanted format a memcard. i did put the memcard into the camera,but it can't use it(it said no memcard in the camera). so i did put back my original memcard. after i wanted switch it on but it says "system error 10". before the memcard change the camera was working. i tried change the battery but it not help. what can i do it? can i reset the camera with buttons?
  • 1 more comment
  • frankcrk Aug 11, 2007
    hi! thx,but it doesn't work. when i put the new battery in (without memcard)at that moment it says again "system error 10" and i can't switch on the camera.. :( think so i will buy a new one. thx for trying!
  • Anonymous Mar 15, 2008
    i hav same problem
  • metra Feb 14, 2009
    I bought a nikon coolpix 4600 in august 2005 and I've been using it. Yesterday it suddenly said system error 1 0. I have tried everything but doesn't work. What To Do?
    Sergeant:
  • 390 Answers
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Posted on Aug 10, 2007
Hello, I have a Nikon Coolpix S6000. It has worked well until this evening when I attempted to erase multiple selected images from the camera. It then froze for a minute and when I got it running again it...
Hi
1) Mostly its card problem
2) You must be format your card in your computer
3) Now put your card in camera and format card twies , if error comes again then do this proces again
4) If this not solve your error then tell me
May 29, 2011 | Nikon COOLPIX S6000 Digital Camera
My Nikon Coolpix L20 will only delete one picture, and then the screen says "please wait" It's been over 20 mintues, and just yesterday it worked. It hasn't been dropped or anything.
This might be a file error on the memory card.
This happens sometimes.
Save what you can from the card then format it in the camera a few times.
Hope this helps.
Feb 04, 2010 | Nikon COOLPIX L20 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens will not come out
Call the manufacturer, it sounds defective.
Jan 15, 2009 | Nikon Coolpix 4600 Digital Camera
Nikon 4600 coolpix
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
System error 10
You can try taking out and replacing the memory card with the original that came with it. You can also take out the batteries for a while and then put them back in. That's what Nikon suggests. If this doesn't work you are told to call Nikon.
Let me give you a little information about this issue. Nikon 4600, S1 and S3 have a faulty operating system. The good news is that there is an update for it. The process of repairing that issue might take an hour or two. You have to hard boot the camera with a jumper setting on the unit to force the new operating system in the camera and then upload all the updates.
Nikon is repairing them for people, but they want you to send it in and are charging people $87 for the repair. You might be able to find someone near you that can do the repair for you much cheaper.
It might just be better to buy a new camera.
Sorry i couldn't help more. Good luck.
Feb 10, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
500 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
