Question about Garden
Pro24ccsgta mixture is this 2 or 4 stroke - does it run on just petrol alone?
3 Suggested Answers
  • 109 Answers
SOURCE: 2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
Posted on May 06, 2009
rycgl
  • 1545 Answers
SOURCE: what is the petrol to
Ratios range by machine and manufacturer from about 32:1 up to 50:1. 40:1 is most common.
32:1 4oz. oil/US gallon gas
40:1 3.2 oz oil/US gallon gas
50:1 2.56 oz oil/US gallon gas
Here is a chart with many different ratios:
http://www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
Posted on Oct 28, 2010
Which mixture is richer: 16.1 or 40.1?
Most 2 stroke tools run on a mixture of 50:1 that means 100ml of oil in 5L of petrol.
Mar 14, 2016 | Craftsman Garden
Plug is oiling up after 15 min of running
Either:
1. If it's a two-stroke the oil/petrol(gas) mixture could be wrong. if you mixed it last year or left it in the tank, the petrol (gas) will evaporate leaving the oil behind making it too oily and fouling the plug.
2. The mixture is too rich - the plug will be sooty and smell of petrol. Check carburettor adjustment and float height.
3. There is lubricating oil entering the cylinder, either worn or broken piston rings or (four strokes only) worn valve guides
Mar 06, 2015 | Garden
What fuel does stihl MS 192 T take, 2 or 4 stroke?
these small engines take 2 stroke oil/gas mixture, usually a 50 : 1 ratio, a little heaver on the oil is better than too light. the oil in the gas lubes the internal parts of the engine. if straight gas is introduced into gas tank just remove & replace with 2 stroke mixture. if engine has not been operated with straight gas, no harm will be done.
Apr 26, 2014 | Garden
TYPE PETROLE AND OLE USED IN 2 STROKE LAWNMOWERS
boat gas works best any of the new 2 stroke oils work well
Nov 14, 2013 | McCulloch Garden
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Husqvarna 55 1997 7351593 whatis the oil to gas mixture
The mixture is 40:1 that is 40 parts petrol to 1 part 2 stroke oil. Use good quality 2 stroke oil, e.g. Husqvarna or Stihl, rather than the cheap stuff you get at car service stations. This will prolong the life of your chainsaw.
Apr 24, 2011 | Husqvarna Garden
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain turns then craps out, run hot
i assume it's a petrol driven probaby 2 stroke? if yes then you need a service on the carb & air filter if the engine is going back ok on idle speed.if it does not & goes off when you release the throttle then you may need to check the compression chamber which might have been damaged by not adding stroke oil in the petrol mixture.Hope this helps and is a 2 stroke engine...
Jun 15, 2009 | Homelite ZR10926 16 Chain Saw
What oil to petrol ratio does this engine run on?
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Apr 18, 2009 | Husqvarna Garden
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
