Question about Plantronics Voyager PRO HD Bluetooth Headset
Plantronics voyager pro hd
Not responding how to Complete reset
  • 91 Answers
SOURCE: need to reset plantronics voyager pro heatset it
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Posted on Mar 23, 2011
HDI Headsets
  • 537 Answers
SOURCE: my plantronics voyager pro will not charge turn on
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Good luck from Headsets Direct!
Posted on Oct 24, 2011
HDI Headsets
  • 537 Answers
SOURCE: how to change plantronics voyager pro plus ear
The link below for the Plantronics Voyager Pro+ has the information you're longing for. Look under "Mix and Match for Best Fit."
Plantronics Voyager Pro+ User's Guide
Posted on Oct 26, 2011
HDI Headsets
  • 537 Answers
SOURCE: I cannot connect my Plantronics
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Posted on Oct 27, 2011
HDI Headsets
  • 537 Answers
SOURCE: how do i put a plantronics voyager pro into
The instructions on the link below will walk you through the pairing process:
Driver for Voyager pro hd windows 7 32 bit
Did you try downloading Software for Plantronics .Audio 478/628/648 - Skype Certified Headsets?
You can get it and other software for the Voyager Pro HD here:
http://www.plantronics.com/us/support/software-downloads/
May 28, 2012 | Computers & Internet
Cant get my voyager 510to connect to my nokia c2-01 mobile phone can you help??
Because this is a discontinued model going with a very new phone. I hope it works for you. Otherwise you may have to purchase a new headset. However when they discontinued that they did not make a replacement. You may want to look at the Voyager Pro HD.
Plantronics Voyager 510 Pairing Instructions
Plantronics Voyager Pro HD
Sep 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
After I complet a call I still get some static in the headset. right now its been going on for 10 minutes. its at a very low volume but annoying
Making sure the headset is fully charged, you'll probably want to try and pair the headset to your phone again. Make sure that any bluetooth devices are removed from the phone. Removing the battery (if possible) for about 15 seconds helps to reset the phone. Follow the pairing instructions on the link below for the Plantronics Voyager Pro.
Sep 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
Instructions:
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot hear anything. Headset is paired and connected, but I cannot hear anything at all.
You want to remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone pairing information for your Voyager Pro headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics Voyager Pro. That should get some sound back in your headset.
Plantronics Voyager Pro User's Guide
Apr 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have Plantronics voyager Pro headset. The microphone is not working. The receiving end cannot hear me
Try deleting your Plantronics Voyager Pro from your phone and then repair them to each other. Sometimes this does correct any issues you may be having. The link for the user guide is included below.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
My ear piece keeps losing its pairing
Please remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone any pairing information for your Voyager Pro headset and pair it again with your phone, following the instructions on the link below for the Plantronics Voyager Pro.
Jan 20, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics Pro bluetooth was working well until last night when I had to reset my IPhone. Now the bluetooth is not working. It appears as if it is not compatible. I tried my son's Iphone who did not...
Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Make sure the phone doesn't have any bluetooth interference loaded on. On the link below for the Plantronics Voyager Pro look at "Listen to the Voice" for turning the headset on and off to reset for pairing and follow the pairing instructions in the manual.
Nov 11, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager PRO HD Bluetooth Headset Logo
54 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
