Question about GE JGRP20 Gas Single Oven
Pilot heats up but gas will not come into bar with little holes in oven
Set the oven to any temp and the igniter heats up enough to light the gas but no gas is flowing to be ignited. The range top works great. The only identification numbers I could find was inside the oven on an metal adhesive sticker. 317B6641p001
    Problem Solver:
  • 5 Answers
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Posted on Mar 23, 2009
SOURCE:
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
Gas wall oven wont come up to temp.
ELECTRIC OVENS:
Apr 07, 2014 | Frigidaire FGB24S5A Gas Single Oven
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
I put the oven pilot light on and soon i turn the knob it turn off
Not understanding the exact problem here. First off, is this oven old enough to have a standing pilot or is it a glo igniter type? If it's a standing pilot, then you don't put it on, it should be lit all the time. If it's a glo igniter, it will glo, heat up and then turn on the gas when you turn the knob to bake and set the temp. you want to achieve. So, I need a little more info to accurately diagnose the problem. I would like to know the age of the range, and the make and model of the range.
Mar 05, 2014 | Ovens
Oven not working
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Nov 22, 2013 | Belling Ovens
Oven is very sporaditic, will heat up get to temp , go to load mode then shut off. Sometime after an hour or two sometime after 15 minutes
Your pilot light is probably blowing out. If you follow the pilot light gas line from the pilot flame back to the main valve, you will see a screw about the size of a pencil in diameter. If you take that screw out, there is another screw down in the hole you just uncovered. You have to have a very small screwdriver to reach that screw. If you turn the little screw counterclockwise, the pilot light flame will get bigger. A lot of times this will help. If you have a drafty location, the pilot will get blown out and that shuts the main gas valve off.
Sep 22, 2010 | Blodgett DFG-100 Gas Single Oven
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
GE JGRP20 Gas Single Oven Logo
358 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
