Question about Maytag Dryers
Heats up without being turned on - Maytag Dryers
  • Maytag Master
  • 8,220 Answers
Heater element shorted to frame. Remove wires to terminals on heater element. Check for continuity between each terminal and frame of dryer. If you get a reading you have a shorted element. I have manuals, videos, and much more Paw Paw's dryer service page
Posted on May 02, 2013
There is heat coming out of the vents when I turn the a/c on and when the heat is on. Compressor turns on normally
if using the a/c on make sure that you turn the heating nob of for the a/c to work them control the nob as require.good lake and have a good day
Oct 10, 2014 | 2002 Nissan Sentra - GXE, without spoiler...
Over heating Mercury Topaz, also the Wipers turn on without me touching the Wiper switch.
Have you checked to see if the head gasket is leaking, and if the park switch inside the wiper motor has failed ?
Sep 19, 2014 | 1994 Mercury Topaz
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
GOODMAN AIR HANDLER, FAN AND HEAT STRIP COME ONLINE WITHOUT DEMAND. WON'T TURN OFF BY TSTAT
the w wire off thermosta controls heat. eithe bad board or thermostat.
Feb 01, 2013 | Goodman Heating & Cooling
Hunter, I have A kenmore electric dryer model 110.64121100. My problem is the dryer heats but the drum does not turn. This is a very strange problem. I turned off the timer and heater was still on in the...
Ok check the belt. if broken then make sure the drum turns freel by hand before replacing the bely. Usually dryers wont heat if the motor doesnt go so perhaps the motor is running without a belt. have a look see. Without an inspection its dificult to pin point Good luck
Jan 22, 2011 | Dryers
2004 CHEVY MALIBU HEATED SEATS TURN ON WITHOUT
The switch need to be replaced. This is a common problem. Understand that he switch is the only breakpoint in that system. If the seat is getting hot without the switch being pressed, there is a short in the switch, thuis the necessary replacement.
Mar 21, 2010 | 2004 Chevrolet Malibu
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
