Question about Plumbing
KWC Suprimo leak. 5-6 years old. sort of a small gush when first turned off then drips which are becoming almost continuous. What do I need to do?
Filter head removed and cleaned but no change after replacement. do I need a new part ?
rylee_smith
  • 8619 Answers
SOURCE: Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 07, 2009
Controlfrk
  • 304 Answers
SOURCE: Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Posted on Aug 22, 2009
rsmith972278
  • 160 Answers
SOURCE: I have two Price Pfister Treviso tub/shower
I had the same problem on mine...it ended up being how tight I had the screw on the handle. I loosened it and it quit. Also, you might try different tightness on the valve nut.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Nov 29, 2009
  • 52 Answers
SOURCE: ghrohe shower valve leaking: when in off position
Sounds like the gaskets are torn or worn out. Local hardware stores sell replacements for just about every make and model out there you won't need any tools other then some screwdrivers and allen wrenches if this is the only problem. When you open the head to inspect (make sure you turn the water main off in your house just in case) check the plastic housing to see if it's brittle or cracked. If it is you will want to replace the entire unit.
Posted on Feb 11, 2010
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Posted on Jul 09, 2010
I have a 2000 Ford Focus, the low oil indicator light was fluttering. When the car was turned off oil was gushing out. Put a quart in and it leaked out. Do I need a oil pump.
no
you need to fix the leak
unfortunately you never mentioned where the oil was gushing out from so there are only 2 or three places possible
the oil sender unit
the oil sensor unit
the oil filter
as the first two will drip rather than gush out the filter is left
they can split around the top rim or when being fitted the oil oil seal was left in place and it pushes out under pressure or the filter was overtightened , deforming where the oils eal is
I suspect that the filter area is the problem and if so the fitment of a suitable filter will fix the fault
Jul 09, 2016 | Ford Cars & Trucks
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
Hansgrohe Mondial 15005000 leaking
the mixer ball springs have become weak take them out and pull them out using two pairs of pilers then re-install them.
Dec 03, 2013 | Hansgrohe Plumbing
Reliance 501 - purchased house a few years ago don't know how old it is - water is dripping from bottom near plate can feel a small rectagular hole with what seems a small piece of metal in the middle -...
unfortunately not, if the tank is leaking from the casing, it needs to be replaced. i would suggest, if your not paying water tax, you can run the tank for as long as you like, just divert the leaking water into a floor drain. but i do highly recommend getting a new tank. that drip can turn into a flood in a matter of days, all depending how bad the inner wall has corroded.
Jun 20, 2010 | Water Heaters
Hi
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Maytag Dishwasher 2 years old leaking
open the door of the dishwasher and check the seal. It may have just gotten worked out of place or it could be deteriorated enough that you will need to replace it.
Dec 31, 2008 | Dishwashers
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
