Question about Watches
Citadel nitelite need the back
Is the back of my generva watch 5573 s a pop off or screw off?
Best to take it to a jeweller as battery replacement if not knowing how can damage the movement. Otherwise a screw back has little notches on the side of the back and a press back is smooth. You will need a back opening knife to open.
Nov 27, 2017 | The Watches
How do i remove the back to replace the battery on this watch
Watch backs are usually either push-fit and simply need to be levered off, or are twist-fit and need to be rotated off. If there are a number of indentations around the rim of the back then it is likely to twist off. You need to get a suitable tool or tools to remove the cover or you will damage the back of the watch. Check on amazon or ebay for watch repair tools. Getting the cover back on is usually harder with push-fit and is more likely to lead to damage without the correct tools.
Or take it to a watch shop and they will replace the battery for you!
Jan 08, 2016 | Watches
How to change th battery in a Citadel Quartz watch?
Bass Pro Field Stream Citadel Watch for Men battery Questions
Try this link to know more
Electro help
Aug 14, 2014 | Watches
Need to Replace back piece of my watch?
No. Most likely not. Try contacting the manufacturer and give them a description of your watch. They most likely wont be able to help you becuase you need the numbers off the back of the watch in order for them to identify the watch...
Jul 18, 2013 | Pulsar Watches
How to remove watch back
here is some videos that may help you
Mar 14, 2013 | Watches
Guess watch how to take back off to change battery
You must first determine if the watch has a screw down back or snap off back.The top picture is a scre down back and the bottom is a snap off. If it is a screw down back you will need a watch case back opener to open. If is is a snap off you need to look around the back and find the little notch. you can then take something like a butter knife insert the edge between the case back and the case and snap the back off.
Apr 02, 2012 | Seiko Watches
Cardinal watch wr100m manual
I have a cardinal nitelite watches,
I only have one button and the other is to adjust the time by hand , the light works but the hands do not turn, can you help me?
Mar 26, 2012 | Watches
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
Need to open. coleman 40-334 watch not sure if the back is threaded
mcdevito75 here, If the back screws down, you"ll see a series of square holes around the edge of the back cover, in this case you"ll need a special tool called a case back remover tool to un-screw the back cover. If there are no square holes on the back cover, most likely it"s a press type back cover and some of these cavers are very hard to get back on wothout another tool called a case back press tool, these mentioned tools are available on ebay, but, with just a battery replacement, the time and tools you may need the cost is more than a watch repair shop would charge you. Best Bet, look for a small watch repair shop in your area for this once a year or even longer battery change.
Feb 11, 2011 | Watches
I have a columbia watch cl 7204. does the back pry off or rotate?
mcdevito75 here, Basically there are 3 ways to remove the watch back, If there are 4 screws holding the back onto the caseing you"ll need jewelers screwdrivers to reove the screws and cover, if there are square holes going around the edge of the back cover you"ll need a special tool called a case back remover tool available on ebay to un-screw the back cover, or the cover simply prys off. Look for a tiny tab on the back cover you may need a magnifier glass available at most Dollar stores or there may be a **** between the back cover and case of the watch to pry off the back cover, use a sharp knife and carefully twist the knife oncwe you find this tab or ****.
Sep 21, 2010 | Columbia All Sport watch
Watches Logo
47 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
