Question about HMF Polaris Sportsman 550-850 X2 2010 Swamp Series Slip On Exhaust System
Horn Wiring Diagram
Need to know how to wire an after market horn.
Make my horn honk
I looked at info for a Silverado 1500. Use a test light to check for voltage at horn fuse in under hood fuse box. According to this diagram, the horn relay has to be energized. Have a helper hit the horn switch when you check voltage at horn fuse. If hot, have to check wiring circuit to horn. In the diagram, dark green wire is voltage and black wire is ground. You could actually use jumper wires from battery for voltage and ground to horn, for testing.
Nov 13, 2017 | Cars & Trucks
Need horn wiring diagram for 2006 pt cruiser
http://www.bbbind.com/free_tsb.html Ok here is a wiring diagram for the horn circuit on your 06 PT Cruiser . Enter your vehicle info year , make , model and engine size . Under system click on interior & driver Amenity . Under subsystem click horn . You will see
1 diagrams found. with a search button under it , click search . Click on the blue link and then your horn diagram will pop up . It's probably nothing your going to understand . Do you have a air bag light lit on the instrument cluster ? Do you know anything about computer controlled systems on automobiles ? C.A.N - controller area network ? You should read this before you mess with any wiring How to Diagnose Controller Area Network CAN Also google chrysler TIPM - totally intergated power modul problems .
Feb 13, 2017 | 2006 Chrysler PT Cruiser
2005 Honda Activa wiring diagram
Hi, Anonymous first check for continuity at the power and ground wire at the horn, then check for continuity at the horn button, back in the day there was a small adjustment screw on the back of the horn, by turning it one way or the other you could set the limit on how much the diaphragm vibrated.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2005 Honda Activa wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda Activa Scooter Horn not working
Learning to repair the horn of Two Wheeler Hindi
Honda Activa 2011
Sep 18, 2014 | 2005 Honda Activa
Wirng diagram for a sc50 sonic pride scooter power switch, horn,horn button,power meter,etc.
Bad boy (or girl of course)! Should have noted everything BEFORE taking it apart. But then you now know that and probably did before .... Oh well, we've all done it... Once. I have a Pride scooter, but not this one. MAYBE someone with a sc50 Sonic will be kind and post a photograph of the underside of their control panel while still wired?? This would help our friend a lot.
Sadly Pride Mobility aren't known for useful things like wiring diagrams or meaningful owner's manuals.
Jun 22, 2014 | Pride Sonic 3 Wheel Portable Scooter
Wiring diagram
test your car's electrical system with a different horn, other than the possible faulty one or test the horn itself, outside the car with a different power source, this is to isolate which is faulty , the car's electrical system or the horn itself, if horn is faulty then replace it, if not check your wirings.
Dec 28, 2013 | 1984 Toyota Pickup Deluxe
Need a fuse box diagram for a 2004 mercury sable. Horn stopped working
1) Check for power to horn unit with steering wheel horn switch depressed. If power present, replace horn unit.
2) Check horn switch operation. Repair or replace.
3) Check continuity from driver's horn switch mechanism and horn wiring. If faulty, then trace wiring back to fuse box and relay assembly.
Make sure you haven't skipped any steps before attacking the fuse box issue.
Nov 03, 2012 | 2004 Mercury Sable
My 2004 freestars horn went on & wouldnt turn off until i started the van & hit the horn
The horn wires needs to be inspected.Click the link below and follow the wiring diagram.You just need to follow the wiring shown in diagram and disconnect the wire getting to horn.Then test it with meter and see if your are getting voltage with horn depressed and not depressed.Click the link below for wiring diagram.:-------http://technoanswers.blogspot.in/2012/02/vehicle-wiring-diagram.html
---------Thanks.
Jan 30, 2012 | 2004 Ford Freestar
Horn does not work. relay and fuse good, need wiring diagram
Had the same problem myself i just replaced the horn itself.
Jun 02, 2009 | 1997 Chevrolet Astro
Wiring diagram
what color of wire is coming from the horn button on the steering wheel to the relay, trying to find why the horn does not work, relay, fuse ok, but can't find a wiring diagram for the horn.
Jul 29, 2008 | 1997 Chevrolet S-10 Pickup
HMF Polaris Sportsman 550-850 X2 2010 Swamp Series Slip On Exhaust System Logo
110 people viewed this question
Top HMF Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a HMF Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
