Question about Epson L200 Original Continuous Ink Tank System cis Inkjet Printer And Scanner
INK PADS FULL
HOW CAN IT BE RESET THIS PRINTER?
  • Epson Expert
  • 76 Answers
Epson L200 ink pads error Epson L200 is an All-In-One printer, All-In-One printer is a printer unit has multiple function as Scanning, Photocopying, and printing. Epson L200 comes with 6 ink bottle consist of 3 Black Ink, and colored ink, 1 bottle for Cyan, 1 bottle for Magenta, and 1 bottle for Yellow Colors pls check epson L200 ink pads error reset
Posted on Jul 05, 2014
Get the ink reset utility with key
Posted on Aug 15, 2013
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
My printer displays E 2 7 that the "printer absorber is full"
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer and start printing again.
1. Turn off the printer
2. Press and Hold both the Power and Reset button for 10 sec
3. While Holding the Power button, release the Reset button
4. Press the Reset button twice then release the Power button
5. Wait until the printer display " 0 " (or RESTART) on the led screen
7. Press Reset button 4x
8. Press Power button 3x and wait for printer to power off
9. Press the Power to turn on the printer
Do this as many times if the first attempt didn't work until it fully reset.
Aug 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
1. Click Reset Main to reset the waste ink counter and
2.
Happy printing.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
My printer canon pixma mp 150, the tank is full..what should i do
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Aug 11, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What does it mean when your printer is saying ink absorber is full
ink absorber pads in bottom of printer have become full of waste ink. would need ink absorber pads and know how to reset counters
Apr 14, 2010 | Canon PIXMA iP1600 Printer
Epson L200 Original Continuous Ink Tank System cis Inkjet Printer And Scanner Logo
302 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
